Results 1 to 3 of 3
    Apr 2011
    Frankfort KY
    15
    Default Chassis dyno articulating arm lcd panel(s) mount
    I would like to make something like this, doesn't have to be as extensive. I need it to mount to the ceiling above a car and be able to swing 2 lcd panels around either side of a car on a dyno. Anyone have a clue where I can get or make some swivel pieces similar to these? Thank you for your time,Dk
    http://www.dkGoodrich.com
    EFI Tuning Solutions
    106lb/min 11k RPM 1.8l
    Nov 2003
    3,625
    Do not know how much you intend to spend... those things are expensive new... if you are not in a hurry, I would check local hospital and university surplus... they are always upgrading monitoring electronics...
    You might take some time to get to know someone in maintenance or facilities management... you may uncover a goodmine..
    Similar arms have been in use for CNC equip for many years... so industrial surplus.... or your locall scrap yard could be a good bet...
    Good Luck!!
    Dec 2009
    722
    Get a machinist to make you to sleeves for a good size bolt that you can insert a UHMW washer in between, long enough that you'll be able to tig them on a some 1 X 2 X .100 rectangular tubing to each sleeve, then you can tig your wall mount at one end of tubing and your monitor mount at the other end.
