I have a very peculiar problem happening to my bobcat 225.
twice, I have run it for about 10-12 hours of total use, and it has gone through 1 full qt of oil each time. Here is the odd part, there is NO blue smoke, or smoke of any kind, and there is no puddle around/in/on the welder.
I have never seen anything like this. I mean, I figure an engine could consume a small amount of oil without noticing it but 1 qt in about 10 hours?
Its an onan p216 Really confused on this one....
Results 1 to 10 of 10
Thread: Missing oil
02-04-2008, 08:47 PM #1
Missing oil
Voigt Precision Welding, Inc.
Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
2007 Silverado 2500HD (tow vehicle)
2000 Camaro SS (Race car)
02-05-2008, 05:19 PM #2
- Dec 2007
- Oklahoma
- 641
Oil useage
Make sure the breather tube is intact.
Griff
02-05-2008, 06:49 PM #3
- Sep 2007
- NE Ohio
- 44
For what it is worth, I have last year, run the same with the same oil consumption problem. I didn't see any smoke either but there was quite a bit of oil around on the engine. Not as much as that which was gone but some.
Tank of gas, qt. oil go figure.
David
02-05-2008, 07:08 PM #4
Miller Dynasty 300DX
Miller Dynasty 200DX
Miller Spectrum 375 extreme
Miller Millermatic Passport
Miller Spot Welder
Motor-Guard stud welder
02-05-2008, 07:58 PM #5
02-05-2008, 08:33 PM #6
I take it its running fine, making good power and such? Sometimes air cooled engines have issues "gunking" up the oil control rings and oil return holes in the pistons, this can lead to oil consumption at power, but no smoke at start up. Multigrade oils are worse for this. You can try Marvel Mystery Oil added to the oil at the next oil change to help disolve the gunk. Also switching to a single grade oil is of help."Better Metalworking Through Research"
Miller Spot Welder
02-05-2008, 08:40 PM #7
- Oct 2006
- DFW area
- 180
Hmmm,,
A quart in 10 hours?
If it was a car going down the freeway, at what do ya figure,,
Taching say,,, 3,000 rpm or so, that'd be-- oh,, something around 80mph?
It would be burning a quart in more or less/about 800 miles.
Its a smaller engine, but you get the idea.
Depending on how old & worn it is, that may be sort of normal 'wear & tear'.
Anyway, as to where the oil is going:
The crankcase vent could be sucking it in and burning it if the rings are just starting to wear enough for ya to be getting blow by gases; but not worn enough to really smoke. After awhile- it will foul the spark plug.
Another possibility is the sealing ability of the exhaust valve guide.
When they wear, oil from the top of the head gets on the valve stem,
but isn't wiped off when the valve opens. The oil on the valve stem gets burned as the exhaust pulse goes past it. This oil consumption won't show up on the spark plug, but will start making a deposit on the exhaust valve stem in the port between the top of the valve & the head.
If it was me,
I'd check the oil level every 3-4 hours.
Maybe go to a little bit thicker oil.
Change it every 40-50 hours, or sooner if it says.
And just run the thing until it gets to be a real problem.
.Last edited by Winger Ed.; 02-05-2008 at 08:42 PM.
"Gone are the days of wooden ships, and Iron men.
I doubt we'll see either of their likes again".
Circa 1920.
Author:
Unknown US Coast Guard unit Commander.
02-05-2008, 08:46 PM #8
- Nov 2007
- 184
How many hours are on the engine?
That's the big question.
Any sign of oil in the airbox/aircleaner area?
Dave P.
02-06-2008, 08:29 PM #9
Thanks guys, I'll try switching oil first....
It has 672 hours on it.
I'm going to keep my eye on a pipeliner around the corner from me in the meantime.... He had it for sale, and then took off the market...Voigt Precision Welding, Inc.
02-06-2008, 08:47 PM #10
OIL mISSING
I had an exact same unit years ago .......... Onan is a nice motor......... Here's the thing.........My dodge truck does the same thing..........to go thru that much oil ........ ya gotta have a small leak some where.........take a better look that motor it can't be buring it ......... past weekend my neighbor asked me to look and see why her garbage disposal wasn't working........put the socket down the inside and NOPE can't turn .........????????? then she said the carpenter put new front inlays above the sink............DUUHHH.......I said maybe he droppped a screw in the sink .......... 2 hrs. later after I took it apart......GD 1 1/4 " drywall screw in the blades ......... works fine now
