Results 1 to 10 of 10
Hybrid View
    Aug 2011
    3
    Question Welding questions.
    Hello everyone am new to the forums have been reading them for acouple days. and decided to sign up for them to ask a few questions if you dont mind taking a few minutes and answering them it would be much appreciated.
    1. what is proferred for boot hight 6" or 8"
    2. do automatic welding helmets come with a manual preset able shade level?
    (note: you know your welding at a sertain amps and preset the helmet to its recommended shade level, will the helmet get darker if needed but no decrease past that preset shade level?
    3. what do you all recommend for respirators welding? both indoors and outside.
    3a. what welding helmets can you use with those respirators if there are any limitations?
    4. are independed spats better or the built on lace guards?
    5. are there any welding helmets that come with a built on leather flap to lessen light glare from behind?
    5a. does adding it on change or void the manufacturing warrenty?
    6. are coveralls with zippers or covered bottons preferred? which is safer if any diffrence and how?
    6a. is high vison synthetic strips permittable within a welding worksite or is there some non synthetic specialty high vision strips if any needed?
    Aug 2011
    3
    bump.
    Jan 2011
    Nolalu (near Thunder Bay) Ontario, Canada
    41
    I'll respond to question 6:
    Zippers and welders are not friendly. Buttons are less likely to experience damage from spatter
    Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
    Aug 2010
    VA
    86
    Default Question 1
    No lace up for me. I have always worn pull on boots. There will be a time you
    will want to take them off in a hurry, also no stiching to burn.
    Old but New
    Feb 2006
    3,711
    mishmac,
    Welcome to the forum. If you don't see what you are looking for in the first few threads, check out the search feature in the upper right hand corner.
    Question 1. In most cases boot height is user preference. I like the 8" lace up style. They provide excellent ankle support. Leather boots and leather laces are less likely to burn up from hot sparks and hot slag.
    Question 2. Most automatic welding helmets are adjustable from shade 9-13. Some, like the Optrel Satellite, are adjustable from 5-13. The 5-9 shades are typically used for low amperage GTAW. When the arc is struck the helmet lens will darken to the preset shade. It will not darken past the preset shade #. number. If the arc is too bright, adjust the shade darker allowing a clear view of the welding puddle. The shade must be set with a dial on the helmet.
    Question 5. I am not familiar with any helmets having guards for shielding backlight. I cut my own from thin leather. I use a thin magnetic strip glued to the helmet back with contact cement. I also glue a thin magnetic strip to the leather flap. I keep an assortment of extra flaps. This makes for easy removal and replacement. The flaps will help shield your eyes from back lighting as well as keep sparks from rolling down your neck. Question 5a. Adding such a shield should not affect the manufacturer's warranty.
    Question 6a. Safety clothing is typically job site specific. Check the manufacturer's specification on visibility strips. You want something non flammable. Somewhat off topic is clothing. Cotton is the safest choice. Polyester and cotton blends will go up in flames in only seconds if ignited. Sometimes all is takes is a few sparks. Be safe.
    HAWK
    Aug 2011
    3
    thanks for the replies, much apprecate it
Tags for this Thread
