Results 11 to 20 of 27
    8,006
    Those particular spoolguns are made in china
    The whole problem is the tip. The nose of it is too small for the heat. I have a conversion to change them to the regular Miller mig tip and the problem is solved. I can run .035 alum all day thru a standard .030 mig tip with zero issues. I can fix your nozzle to fit the bigger tips...Bob
    This looks like the simple elegeant solution I would hope to find. I may try it on my 3035. Thank you for taking the time to spell it out. It seems simple when somebody tells you how. LOL.
    Thanks for spelling it out for us welding dummies.
    3,927
    Quote Originally Posted by Bob La Londe View Post
    Nah you aren't dumb but i think someone who engineered the gun is. Oh well it took me some thinking to see what needed changed and that change worked great...Bob
    Dec 2011
    Default I would love to have my converted
    What such a fine improvement set you back for metal masters
    3,927
    Quote Originally Posted by sharkm View Post
    Just send me your inner barrel tube and i will do it...Bob
    Dec 2011
    3
    I just got my own spoolmate 100 with the 211, I haven't hooked it up yet, but I did notice that it came with brass .030 tips???? I tend to use .035 with I think .045 tip at my last job that were AL. Will it work with and AL .045 tip? or should I look to mod it?? thanks
    3,927
    Quote Originally Posted by scubajeep1 View Post
    Modify it you will be glad you did. You don't need an .045 tip to run .035 wire the .035 tip is plenty big enough. The tips are usually .010-.014 thou bigger than whats stamped on them. .030 tips will run .035 wire all day just fine i do it all the time...Bob
    Dec 2011
    3
    Hello,
    OK so how do I get the tube out of the gun, it looks like would have to open the plastic body to get to the nut that hold the inner tube in place, is that so. (I have never opened one up before.
    cheers
    Nov 2009
    South Alabama
    257
    I modified mine and put the heavy duty barrel for a 3035 on it, works great
    "The only source of knowledge is experience." Albert Einstein
    3,927
    Hello,
    cheers
    I think 4 or 5 screws to split the plastic case and then an open end wrench to get the barrel nut off. Then another screw to get the tube from the barrel...Bob
