From what I'm reading the Plywood is not sitting on top of the 1.5 square tube
beam
..the Weld tab is going to be carrying the load of the 18" x 7' 3/4" Plywood and also the sheite ya shove on the shelf.
I assume you are using Weld tabs so that the wood sits flush with the 1-1/4" steel, for Aesthetics
Results 11 to 20 of 24
Thread: Steel strength question
08-15-2011, 02:48 PM #11
Ed Conley
MM252
MM211
Passport Plus w/Spool Gun
TA185
Miller 125c Plasma 120v
O/A set
SO 2020 Bender
You can call me Bacchus
08-15-2011, 03:38 PM #12
- Nov 2008
- Colorado Springs
- 272
While you are calculating
Substitute 1" x 2" x 11ga rect tube.
84" x 18" shelf, bet you get to 500lbs/shelf pretty easy.
That is equally loaded as all shelf systems state
Assemble the rect tube 2" tall
You might be able to save some $ and use 1/2" plywood.
Cost... almost the same.Live Right Have Fun
XMT350 CV/CC
22A Feeder
MM175
TB302
12vs Extreme
Hypertherm PowerMax 1000
20" x 40" CNC Mills (2)
16" x 60" engine lathe
65 Ton edwards iron worker
3/16' x 24" power slip roll
16' power feed mitering bandsaw
and other fun toys
08-15-2011, 05:54 PM #13
- Oct 2006
- Illinois
- 458
hi,just look at the shelving inits they sell at menards, lowes, or home depot. they are tooth pick material and have load ratings that scare me. you can even check out the pallet shelving ratings for a closer look.i would just make sure you run the plywood grain in the right direction.good luck, bob
08-16-2011, 05:18 PM #14
Member
- Dec 2009
- 43
08-16-2011, 05:40 PM #15
yeah could be that way also- dunno, no drawerings
Ed Conley
MM252
MM211
TA185
O/A set
SO 2020 Bender
08-20-2011, 07:37 AM #16
- Jul 2011
- 10
Yeah the tabs are just to secure the wood to the tubing. The wood will be sitting on the tubing. I will be picking up the metal on monday, and hopefully my new digital elite helmet will be here early next week as well.
08-24-2011, 09:23 PM #17
- Jul 2011
- 10
I started cutting the steel tonight. Going to get everything prepped, and laid out so I can start welding first thing Saturday morning. It was 108 degrees out there this evening. Pictures to come once I get something worth taking a picture of.
08-28-2011, 05:27 PM #18
- Jul 2011
- 10
It is now mostly done. I need to weld on the tabs to secure the wood shelves, weld on some plate feet to make it easier to level, weld on the wall stand-offs, with lag bolt tabs to secure it to the wall so it won't tip, and then add some paint, before finally screwing down the wood.
In the last picture you can see the mess I am trying to organize. It will go in the spot where the 2 flimsy shelves are located, and what doesn't fit on this shelf, or have a spot on my future work bench or welding table, will find a home in someone else's home, or the dumpster.
At that point I will have enough space to work and not trip over extra truck parts, and christmas decorations.
08-29-2011, 08:27 AM #19
- Apr 2011
- 306
Well that's one way to do it...
...but why the extra cutting and welding? Full length legs would have reduced your work a ton...and save yourself from more work but skipping the tabs and notch the wood. Secure it if you must with self tapping flat head 1/4" screws into the tubes. I would have (and did) use 2" x 2" x 1/8" angle for it all. that will hold anything I can lift up on it.
Just For Home Projects.
08-29-2011, 12:15 PM #20
- May 2011
- Bossier Parish La.
- 384
By doing it this way the load of each shelf is supported directly by the leg section underneath. If he had made full length legs, the load of each shelf would have been supported by the welds themselves. The welds in this case just keeps everything lined up where it needs to be. He also gets more hood time to play with his new MM210.
