Results 1 to 10 of 18
    Default How do you make a....................
    Halfmoon cut on the end of a piece of pipe like this >>>>>>>>> ) Thanks all!
    Central Fla.
    311
    Hole saw, plasma cutter, o/a torch, grinder with grinding disc or cutting disc, depending on wall thickness - tin snips, nibbler, pipe notcher, and probably others.
    Hardly enough info to give a definitive answer.
    Jan 2008
    calgary
    9
    Default cutting curves
    in the past i have made a jig and used a hole saw of the same size as the tubing to cut the curve
    ( take a block of wood , put the tube on it and nail side rails on to hold the pipe between them, then drill a hole the correct size near the end. flip it over with the pipe under the hole where you want the hole and drill it out with the hole saw. just be careful that you have a block of wood under it to save the hole saw from getting damaged.) the end of the pipe has the curve!!
    southeast texas
    47
    Like what? i don't see a picture am i missing something? i guess you are referring to a saddle? if it is small pipe like 11/2''or 2'' i set my chop-saw at 25deg. and cut off a centerline, anything bigger i use my wrap-around and lay it out with a soap stone. i hope this helps.
    356
    if you are talking about bigger pipe they make attachments to go on saddle bevellers to make thos types of cuts, otherwise there is the grinder and torch to make the cuts
    mm210
    maxstar 150
    The arrows here are pointing to the kind of cut i'm talking about > ) < I guess you could do it on any size pipe. I guess you could call it notching the end of the pipe so you can weld it to another piece.
    May 2007
    729
    I'm a little confused by what you are asking for, but I'll take a stab at it and guess that you are trying make templates to cope pipe.
    To save a bunch of long winded explanations, I'll give you a quickie shortcut that will serve your purposes:
    http://www.harderwoods.com/pipetemplate.php
    Follow this link to the HarderWoods site. Fill out the pipe information on the left column, and it will generate templates for you. Print them out onto paper, and transfer them to cork or paper gasket material, cut them out and you are ready to go. I myself, have used this software to make templates for some oddball stuff, and then I transferred them over to a flexible, thin, magnetic material that I have which holds it to the pipe quite nicely.
    The only information you will need is pipe O.D. and wall thickness, and if you have it closeby, just use a tape measure, or I can supply you a link to pipe schedule charts. Mathey Dearman used to have a good one.
    I have built several grill guards, winch guards and head ache racks for Class 8 semis using coped pipe, so I will offer you a word of wisdom: Measure your pipes VERY carefully.....When you transfer over your measurement to the pipe to be cut - lets say (for example) that 15" is what you need - remember that the 15" is from the BOTTOM of one coped joint, to the BOTTOM of the other coped joint. DON'T FORGET to add the 15/16" (for example) to accomodate the depth of the cope for each end when you lay out your cut lines. After you cut the pipe, then use your templates to chalk out the copes, and the bottom to bottom measurement should be 15".
    Hope this helps.
    On Edit: I see that you are on WW under the username "Metal Man", asking the same question, so I'll copy & post this over there as well. Don't know which site you view more.
    Last edited by Black Wolf; 02-02-2008 at 06:49 PM. Reason: Change URL link. Works fine now.
    Later,
    Jason
    Professional Spark Generator by Trade.
    put the pipe in a chop saw and cut 1/2 the end off at a 40% angle then flip it over and do it again. you will end up with a saddle (see pic)
    you can alter the % to acomodate non 90% intersections.
    quick and easy.
    Easy as pie!!!!!! Thanks alot for the info and pic! .....Tim
    Feb 2006
    411
    Hey James,
    I like that info....neet
    . Thanks for sharing with us
