Most replacement mufflers for older vehicles are aluminized steel. What is the advantage of aluminized steel over galvanized steel? Does it hold up to heat better?
Thread: aluminized mufflers
02-01-2008, 05:53 PM #1
- Jan 2008
- northern california
- 317
aluminized mufflers
02-02-2008, 09:13 AM #2
It must have something to do with the heat. Where i used to work we made giant ovens and the skins were aluminized....Bob
02-02-2008, 04:00 PM #3
gl trying to find a galvanized muffler, they are all aluminized, its much the same idea as galvanizing, resists corrosion, and last a very long time
mm210
maxstar 150
02-03-2008, 01:56 PM #4
My aluminized Flowmasters have been through 12 Michigan winters and have only a small amount of rust on them. The rest of the exhaust system has rotted out several times!
02-06-2008, 10:30 AM #5
- Nov 2007
- Jackson, MI
- 57
02-06-2008, 02:51 PM #6
- Jul 2007
- Southern NH
- 233
02-06-2008, 03:19 PM #7
02-06-2008, 03:51 PM #8
- Jun 2007
- Camden, SC
- 156
SS Flowmasters No Longer Available
Both the 304- and 409 Stainless Steel "Hushmaster" mufflers have been discontinued. All Flowmaster mufflers are manufactured from aluminized 16ga steel WITH THE EXCEPTION OF the new Super 44 Off-Road series, which are made from 14ga diamond plate (steel) and then aluminized. All muffler tubing is aluminized (unless ordered from a specialty shop or custom fabricated) and is usually either 18ga or 16ga.
http://www.flowmastermufflers.com/pr...oducts_id=4157
Clint Baxley
Baxley Welding Service
Rembert, SC 29128
02-06-2008, 06:15 PM #9
I'm a dealer for Flowmaster
You can get most Delta Flow/40 and Delta Flow/50 Flowmasters in 409 SS and Hushpower II Flowmasters are 309 SS
