Thread: New Welding rig
    Sep 2009
    Alberta
    37
    Default New Welding rig
    I decided to try something different with my next portable welding rig.
    Since I often use my pickup to grab materials and parts for the jobs I do, I've been running two trucks in the past. A pickup and my welding truck.
    This time around I'm going to try the trailer idea.
    Here's some pics of it so far, not all completed yet but its done a half dozen jobs so far.
    Jul 2010
    Salem, NJ
    294
    I always stayed away from the enclosed trailer rigs because of the air flow required for the welder. As long as that is ok, I suppose that it would be great.
    Jul 2011
    Tampa FL USA 33617
    17
    I love the last photo..looks great with the tool box under the work bench..
    Mar 2010
    488
    Everything will stay much cleaner inside. Nice setup.
    Dec 2009
    Northern California
    179
    Nice to be able to close everything up and protect it from the elements!
    Nice and clean and everything should have it's place!
    Aug 2004
    Milan Michigan
    1,837
    There are advantages and disadvantages to every set up.
    Trailers are easier to steel in most cases but if you need to chase a part you can leave your guys woking while you take the truck.
    A truck mounted rig is more professional but your stuff is out in the elements.
    Good luck with your new rig.
