Results 1 to 2 of 2
Thread: Plasma Gouger
    Sep 2011
    1
    Default Plasma Gouger
    Hi,
    I am new to this forum and I need some advice. We have a plasma gouger thermo dynamics. We are having problems and are at our wits end. I am needing to find out if you have any ideas of what direction to take, wether we should get this one fixed or just buy a new one. This is obsolete and very expensive to replace. The problem we are having is that the tip saver board has two 1n4007 diodes that keep blowing and we just can't find anything shorted that would cause this to happen. I would appreciate any advise you could give me and thanks very much for your help!!!!
    Darla
    May 2009
    Central North Carolina
    142
    Those are small diodes, 1 amp at 1000 PIV. They're likely the rectifier for the control circuit. Sorry, but I don't have any experience with your machine. Most anything going bad in the control circuit could cause these to blow out, and the current is so low that you won't likely be able to see a component that the magic smoke has been let out of. Only someone with the schematics and good trouble shooting capability will be able to find this problem. Unless you can find evidence of magic smoke or a broken wire connection it's very difficult to fix circuits like this on your own.
    Thermo Dynamics has good customer service. Have you called them? They may be able to diagnose the problem over the phone, or at least tell you who in your area could fix them.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    Miller DialArc HF & DIY Cooler
    2 Miller Digital Elite and 3 Fixed Shade Helmets
    2 O/A torch sets
    DeWalt 18 volt 1/2" Driver/Drill
    DeWalt 18 volt 6 1/2" Metal Saw
    DeWalt Porta Band & SWAG Offroad V3 Table
    Milwaukee 8" Dry Cut Saw
    Milwaukee 14" Dry Cut Chop Saw / Delta Stand
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Milwaukee Hole Hawg 1/2" Drill
    Wallace 5 Ton Gantry
    Too many hand tools
Tags for this Thread
