Page 1 of 3 123 LastLast
Results 1 to 10 of 23
    Jul 2011
    Huntington, NY
    118
    Default Synchro 250 blowing breaker
    My Synchrowave 250 is plugged into a 50 amp circuit. The most I've cranked it up to is 150 amps AC. The funny thing is that the breaker never blows under load. It will trip while the fan is running and I'm not welding with it. It has blown with the machine dialed at 100 amps also.The prior owner, who was it's original, states he never ran it over 100 amps. I can't see him dealing with the breaker blowing all the time. He had it plugged into a 50 amp circuit as well. I'm thinking I have a bad breaker, but am I expecting something unrealistic from this machine on a 50 amp circuit?
    Deltaville, VA
    2,239
    Yes you are.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
    Jul 2011
    Huntington, NY
    118
    Why would it trip the breaker when the fan is running and not under load? It would seem to me that if the circuit was inadequate, it would trip under load. Also, if I keep it at 150 amps max, is a 50 amp circuit really not enough?
    1,915
    If your machine has PFC it will draw a lot of amps at idle as well as welding. Not saying yours does but a possibility. Your breaker could be weak, the machine could be drawing more than normal for some reason, if your in an area with high heat right now the power coming in could be low due to demand. Could be many things as well as it should be on a minimum 100 amp circiut.
    Jul 2011
    Huntington, NY
    118
    I'm thinking it has PFC. Also, my manual says the fan should only operate when needed. Can I remove the PFC and still use the machine? Is it easy to do?Also, if my machine lacks fan on demand, can I retrofit it?
    Oklahoma
    737
    Quote Originally Posted by Drf255 View Post
    Unplug the machine and wait several minutes to insure the capacitors have dis-charged before proceeding.
    Facing the machine, take the right side panel off. Inside you will find 4 capacitors about the size of tall beer. These are the PFC capacitors. Unplug, remove them and the wires to the capacitors and re-install the covers.
    Consult Cruizer on the fan on demand question.
    Griff
    4,486
    You got a machine that calls for 100A and you are feeding it 50,, whats the mystry? Also,,, verify the wire in this 50A circuit.
    4,486
    This machine is not plug and play, does not come with a factory plug. No cord, no recept. Easily has the potential to overload a electric circuit or service.
    4,486
    I got a monster,, the cord is undersized and I fudge a bit on the breaker but I am the user, its rare and limited, if I needed to today could wire it to full power if needed. This type of machine isn't for everyone. We have hobby types here working from 30A service, getting a suitable machine was cheaper than an upgrade.
    I would get a big ole fat piece of wire, for a home shop the one the manual calls for would be fine and breaker of 100A, maybe even as low as 70, would have to look in my collection, I would be tempted to leave my existing 50 (after looking at wire size and making sure connections are tight) for standard equipment. It can be cord and plug connected but I also might be tempted to wire it straight to a breaker provided the panel was in the same location so it could be used as disconnect.
    Jul 2011
    Huntington, NY
    118
    Quote Originally Posted by griff01 View Post
    Unplug the machine and wait several minutes to insure the capacitors have dis-charged before proceeding. Facing the machine, take the right side panel off. Inside you will find 4 capacitors about the size of tall beer. These are the PFC capacitors. Unplug, remove them and the wires to the capacitors and re-install the covers.Consult Cruizer on the fan on demand question.Griff
    That's it? No further connections needed?I'm sorry, who or what is Cruizer?
    Yes. I'm a hobbyist who bought one machine to last a lifetime. I understand that it needs a bigger circuit, but I will never push this machine to it's capability. The prior owner Used it for 18 yrs on a 50 amp circuit without difficulty.
