Results 1 to 10 of 10
Thread: mini dump bed
    Jun 2011
    5
    Default mini dump bed
    I have been toying with the idea of making a mini dump bed for my garden tractor. I have a 3x5 cart with four wheels, that I tow around. I would like it to dump. Instead of hydraulics, I'm thinking 12v scissors Jack. It has the up down controls already. It strong enough to lift a truck up. What do you think? I'm trying to find some plans that would work, if I scaled them down.
    Any input?
    Jim
    Jun 2011
    5
    And que crickets.
    Jun 2011
    1
    cricket cricket
    Jun 2010
    Goochland, Va
    32
    Pictures of the patient would be helpful - let's see the trailer and the jack. Sounds like a good idea to me - would pay careful attention to where forces will show up on the bottom of the trailer.
    Jun 2011
    5
    I didn't get a lot of responses, so i don't know if any one is interested.
    i finished the project, i scrapped the scissor jack idea. i just went with a linear actuator instead. It looks good, but seems to be sort of weak. i went with a warner 600lb. But i would be lucky to dump 150lbs. i don't know if the setup is bad, or maybe the actuator is problem. i bought it on ebay and maybe its not want the seller said. it looked pretty generic, not markings.
    Apr 2011
    356
    Default You are lucky...
    ...it lifts 150lbs. You created such a long lever arm that you have quite a multiplier on what the cylinder sees as far a load goes...maybe a practicing engineer can give you the correct formula for the load that thing "sees."
    Just For Home Projects.
    Jun 2011
    5
    Here is the redesigned dump wagon. I shortened the frame base by 13inches and move the hinges from the back of the wagon to 1/3 up the frame. It seems to have alot more dumping power. Should of paid more attention to the physics the first time around.
    Jun 2011
    2
    Default Good Job
    Hey man, that is pretty awesome. Good work on it.
    Apr 2010
    Newport News, VA/Fremont, OH
    182
    Just throwing in my .02, but would an actuator from an old satelite dish work? I'm sure there's a bunch of those laying around junkyards, I just scrapped a dish not too long ago, and the actuator still worked
    Jun 2011
    5
    Quote Originally Posted by hockeyguynick View Post
    I don't know what an actuator for a satelite dish is rated at. I bought that one on ebay.
    It's a warner rated at 600lbs and a 6 inch travel.
