Normally there are two bolts, one for the adjustable jaw to pivot on, the other to set the angle. Set angles from the adjustable jaw face to the blade as the degree thingy is normally never correct.
Results 11 to 12 of 12
01-29-2008, 05:40 PM #11
Normally
01-29-2008, 06:56 PM #12
Member
- Jun 2006
- 70
Here's a Chop Saw Plans I bought off of Ebay and found out after the fact that they are on the net for free. Here's some pictures of The one I built. It piviots the Whole base so you don't have to turn the whole piece of steel. Look at the saw I have its a cold chop saw blade doesn't give when I've cut angels.
If I'm cutting a lot of the same angle I use the Dayton Horizantal Band Saw.I BLEED MILLER BLUE!
DoubleEdgeWelding@kc.rr.com
GROUNDED IN FAITH!
I have what my Big Bro JESUS has Blessed me with:
Miller 251,Miller Syncro 180,Miller 625 Plasma Cutter
Want to Buy a Miller PC-300,
Dayton 7"x12" Horiziontal Band Saw, Dewalt 14" Abrasive,& Cold Chop Saws,4' Box/Pan Brake,Also A Complete Wood Shop. Now alls I need is a bigger shop!
