Results 1 to 10 of 12
    May 2007
    20
    Default setting 45 degrees on metal chop saws?
    Hey this might be a stupid question, but does anyone know why there are always two bolts on the thing that sets angles on metal chop saws and the proper way to set them? Do you guys just loosen one and keep the other still, or do you loosen both and set it at for example 45 degrees and hope its the right angle?
    For example, i had to set my angles at 22 1/2 degrees for some welding and i had to cut a piece on my regular wood chop saw and use that as a guide everything and it gets annoying, there has to be some secret to use of the two bolts? Thanks in advance..
    Indiana
    541
    Nope it's just a simple clamp. Chop saws are not built for accurate cuts. Cut pieces that you know are square are good to use for setting up the clamp.
    Tim Beeker,
    T-N-J Industries
    (my side bussiness)
    Esab 450i with wire feeder
    HH135 mig
    Miller aircrafter 330 - sold
    Marathon 315mm coldsaw
    table saw
    Dewalt cut off saw
    Sand blast cabinet
    lots of hand grinders
    Harris torch
    beer fridge
    Louisiana
    87
    Quote Originally Posted by tnjind View Post
    Yep what he said, or you could use a speed square to check angle.
    Scottsdale, AZ
    173
    Is there any reason why I cannot use my high$$ DeWalt saw that cuts all those fancy angles when I do wood working...convert it to a chop saw by just adding a cut-off blade??
    Don
    Scottsdale, AZ
    www.savagesun4x4.com
    MillerMatic 211 AS
    Hypertherm PowerMax30
    Bernard 300 Amp Q Gun
    Bernard 200 Amp Q Gun
    Milwaukee Band-saw/stand
    10 Angle Grinders 8, 4 1/2" -2, 7"
    DeWalt Chop Saw
    Craftsman Twin-Blade Saw
    12 Ton Shop Press
    Optrel Satellite Helmet
    Miller Elite Helmet
    2,636
    Quote Originally Posted by SavageSunJeep View Post
    Most Abrasive blades are not designed to run at the speed a Wood Mitre saw turns.
    There is one company that is selling blades that they say will work.
    I'll have to find the link.
    But I wouldn't want to screw with my mid$$ Compound Mitre saw- It only gets fed wood
    http://www.bulletindustries.com/catalog/
    Scottsdale, AZ
    173
    OK, then why don't they have a Chop saw that is like a compound mitre saw to cut angles etc et
    Don
    Scottsdale, AZ
    MillerMatic 211 AS
    DeWalt Chop Saw
    12 Ton Shop Press
    Miller Elite Helmet
    Alaska
    732
    The mechanism would get clogged with the metal and blade particles.
    And the price of the unit would go up so high you would be better off getting a cold saw. http://www.bii1.com/coldsaws/coldsaws_manual.htm
    TJ
    Jul 2007
    Lancaster, Pa
    431
    I use a square to set my 45's or 90's. You cant rely on the settings on the saw and I snug up both bolts. I also never use the lock down handle with the bolts, it doesnt hold very well anyhow. The only trouble I have with mine is the blade flexing if I only want to cut off a 1/4" of material.
    Heres a link on the evolution tools and blades.
    http://www.evolutionpowertools.co.uk/us/index.html
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    southeast texas
    47
    I have the same problem as KBar, if i want to take a little off it makes for a tough cut because of the blade flex. as for cut angles i use my speed square for 45.s and 90.s. i made several wood templates for other angles on my wood chop saw,in a pinch before i got my metal chop-saw i put a blade on my makita. one cut said i was sorry never again.
    Nov 2007
    Saskatoon, Sask, Canada
    1,267
    They're called "chop" saws because "hack" saw was allready taken!
    I just use my angle finder/ protractor thingy, if I need to get closer than that I find a bandsaw.
    We have a Dewalt mitre saw at work that we us for cutting Alum. (special blade) well I think we own three of them now. They survive pretty well depending on who is operating them, but we've had them all repaired once. One of the guys found out they don't cut stainless pipe very well I'm sure if it was someone that would have known better it would have been fatal!
    at home:
    2008 Suitcase 12RC
    Spoolmatic 30A
    WC-24
    2009 Dynasty 200DX
    2000 XMT 304
    Sold:MM130XP
    Sold:MM 251
    Sold:CST 280
    at work:
    Invision 350MP
    Dynasty 350
    Millermatic 350P
