I've got a very conveniently placed range outlet, a NEMA 10-50R, near where I want to use the welder. It's a 50 amp circuit, straight from the box to the outside. We've got a dryer plugged to it now, but it's got the 10-50 which is a "range" plug: three flat blades, one vertical, two slanted like \ / . I have a range cord, which has the same plug. I wanted to see if I could wire it up to that with the NEMA 6-50 at the other end. But the range plug is a 3 pole, and the Miller a 2 pole. The 10-50 has a 125 and a 250 and what, a neutral, the vertical? And the 6-50 two 110s, i.e. both hot?
So can I just wire the two hots to the \ and /, and neutral to the | and be good to go?
Rob
Results 1 to 10 of 12
07-10-2011, 08:43 PM #1
- May 2011
- 11
Wiring Millermatic 211 to NEMA 10-50R
07-10-2011, 08:57 PM #2
- Sep 2005
- 4,246
It will work. Done all the time.
07-10-2011, 10:46 PM #3
- Sep 2002
- Clark County, NV
- 2,696
Yep, while it is a "neutral" on the dryer/range receptacle, it can be used as a ground with no issues whatsoever. The neutral is a "grounded conductor" designed to carry current in normal conditions. The ground is a "grounding conductor" designed to carry the current in a fault. My first shop used a MM175 plugged into a dryer receptacle for two years.
07-10-2011, 11:21 PM #4
- Jul 2011
- 21
As long as there's no other outlets on the same circuit (very rare with dryer outlets, but I've seen it a few times), you can safely use the neutral as ground.
--Bushytails
07-11-2011, 07:47 AM #5
- May 2011
- 11
And in terms of wiring, does it matter how the \ and / prongs are wiring to the Millermatic plug? Should I just keep left to left, right to right, and middle to middle?
07-11-2011, 07:48 AM #6
- Sep 2005
- 4,246
And ideally this circuit originates from the main entrance panel not a 4 wire fed sub, then the N is fine, as good as it gets.
07-11-2011, 07:49 AM #7
- Sep 2005
- 4,246
Mac,, I see a few posts lately, so you are back,,,, been hiding where? Good to see you.
07-11-2011, 07:53 AM #8
- May 2011
- 11
07-11-2011, 10:55 AM #9
- Sep 2002
- Clark County, NV
- 2,696
07-11-2011, 11:24 AM #10
- Nov 2003
- 2,019
Mac
good to see you active again.....
