FOR SALE!
Miller Syncrowave 250 DX Welder
$3,500
Hanover, Pa
Call or Text Mark at 717-515-8100
Industry standard - Syncrowave® 250DX has proven itself time and time again in the most demanding applications. Its industrial design and construction ensure reliable operation for years to come.
Processes
• AC/DC TIG (GTAW)
• Pulsed TIG (GTAW-P)(optional)
• Stick (SMAW)
Applications
• Precision Metal Fabrication
• Maintenance and Repair
• Light and Heavy Manufacturing
• Fabrication
• Aerospace
• Shipbuilding
• Tube and Pipe
• Automotive
• Vocational
• Syncro Start for customized arc starts allows the operator to choose from three different starting conditions to optimize the application according to tungsten diameter and material thickness.
• Squarewave output with AC balance control features adjustable penetration and cleaning action while increasing arc stability on various aluminum alloys, and helps eliminate tungsten spitting and arc rectification.
• Dual digital meters allow for quick and easy viewing of actual and preset values of amperage and voltage.
• Last procedure recall automatically recalls the last procedure set-up when switching polarity.
• Built-in preflow/postflow provides 0.2 - 5 seconds of preflow and 0 - 50 seconds of postflow.
• Built-in cable hangers on both sides conveniently fold out of power supply so weld cables can be stored to prevent torch or cable damage.
• Built-in consumable storage located on the front panel allows the operator to store and readily access the needed consumables to be more productive.
To view pictures, check out the craigslist ad for this welder at: http://york.craigslist.org/tls/2469439217.html
