Results 1 to 5 of 5
    Feb 2009
    Bay Area
    29
    Default Home made work bench/tool cart/weld table
    Wanted a universal work-station/bench with casters so I can move it around the garage. I donít have lots of space and anything with wheels always seems to work out well. The idea is that Iíll be able to use it for a number things - weld table/work station - steel top/wood top - mount a vise/small brake, etc. etc.
    Size is 24" x 48" by 34" tall (before casters) kind of around a larger Snap-on box. A bit on the high side for my old tall (and heavy) chin-chin vise.
    Goobered-up the welds, never welded 1/8" tube before. Put .030 wire in the machine and cranked it up so I think they are strong - just not very pretty (more grinding). Hard to judge penetration on that dark square tubing with no experience. The idea is to attach whatever material, removable tops to that. In the photo above, still need to weld caster plates to the bottom and drill/tap. Never mind the photo perspective, top/sides seem square within an 1/8".
    That red Rustoleum is not exactly powder coat but hey it's just a work bench after all.
    Disposable maple plywood top and shelf in place - maybe brush on some linseed oil so the dirt and grease don't soak in as much. Good for now, I'll make some accessories as I go along.
    Feb 2009
    Bay Area
    29
    Came up with a simple way to keep the top (wood) from moving around - may still do something with Rivnuts, etc. for mounting a pull handle, steel top, etc.
    I've already attached a highly adjustable pull handle.
    It will have a "real" handle at some point.
    Made the inside above the shelf tall enough to fit other tool boxes...
    Other tops (like the steel) will be larger with overhanging lip/clamping area.
    Jul 2011
    9
    "Goobered" up welds or not, that looks pretty nice and very handy!
    Oct 2009
    Richmond Va
    57
    That's a dog gone good looking work bench. I bought one like that out of one of those machinery catalogs and it ain't got nothing on that one you have there. If you were not so far away I would send you a nice handle I took off of a bench I scraped to make something else. It would work really well with what you have going on there. Nice job!
    Feb 2009
    Bay Area
    29
    Quote Originally Posted by mx842 View Post
    Got a picture of that handle?
