    Jan 2010
    Western Colorado
    25
    Default please help!!computer apps for project drawings
    hey guys i was wondering if anyone new of a computer program that will allow you to draw up isometric views of what i'm trying to build. i'm guessing something like autocad but i'm not sure. i'm planning on building an end table out of some scrap 304 stainless flatstrap and pipe, more just out of boredom than necessity. i can draw it up isometrically on paper and to scale but i have no way of posting my drawings here for some feedback. i would really like to be able to draw the same thing on the computer as i can on paper. if anyone knows of a good app i would appreciate some help. name of the program and maybe the cost would be great. thanks and have a great and safe 4th.
    It is pretty generic for intricate work, but it is FREE. Try Google Sketchup. Just do a search and it will come right up.
    Jan 2008
    northern california
    328
    Default why bother with the computer?
    Why not just have some fun building stuff? Leave the telephone and computer gadgets in the house and practice real layout.
    Ornamental fabrication shop worker
    at home...
    2011 Hobart Handler 210MVP
    2013 spoolrunner 100 spool gun
    Jan 2010
    Western Colorado
    25
    i'm all for having fun and have every intention of doin just that, the material is free and limited though. so basically i'm only goin to have one shot without having to spend any money. so if possible i'd like some input before i finalize any plans, the layout isn't the issue. i'll try that google sketch-up. thank you, i appreciate it
    May 2009
    Central North Carolina
    142
    A good, easy to learn, 3D program is Sketchup and it's available as a download from Google for free. If you watch 15 minutes of tutorials on it you will be able to use it for most of the basic needs, and then you can watch more tutorials to get better from there. It's one of my favorites.
    Just do a Google search for Sketchup and download it. Watch a few tutorials that you will also find with the above search or go to Utube and search for Sketchup. You will be drawing in 2D and 3D in no time.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    2 O/A torch sets
    Milwaukee 8" Dry Cut Saw
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Wallace 5 Ton Gantry
    Too many hand tools
    Jul 2009
    Australia
    1,031
    An accurate drawing is the starting point for most commerial projects.
    A hand drawn drawing is just as precise as a cad drawn drawing.
    Learning cad takes a long time if we are talking about autocad as it was made to draw everything and thus has every type of command. Sometimes the commands are hard to find or work out how to use. Autocad is digital hand drawing as every line must be drawn. The attached drawing was drawn using Microsoft Visio which is another great drawing program. Sketch up is easy to use just as Revit is and Archicad. The big thing is to get one and start spending quite a bit of time in front of your screen.
    You need to find out how to get the cad to draw in a scale you require and how to print off so the print is to scale. Very basic but can be a handful at the begining.
    Good luck Ji
    Grip it and Rip it
    Jan 2005
    Jasper AB Canada
    36
    I've downloaded Apperson's Cad Std, its a free download for the basic version and about $50 (CDN) for the pro version and have spent some time with it, nice for
    2D stuff. If you don't have any intentions to do cut paths and stuff for CNC mills it is fully exportable and importable in DXF and DWG. I have even sent files off to be laser cut and they were all ready for the machine when i sent them. It also has a tutorial and a scale asistant to set up your drawings. Pretty cool for free.
    A Failure To Plan On Your Part,
    Is Not An Emergency On My Part!
    When you build something Idiot Proof..
    Someone builds a better Idiot!
    Scott S.
    Jasper AB
    Canada
    Jun 2010
    Kansas City
    46
    Default I use Turbo Cad
    Turbocad is a great program for the money, it comes with a tutorial and you can save in many formats.
    Jul 2009
    Australia
    1,031
    This is an isometric drawing I did with Microsoft Visio.
    Great little program and pretty easy to use.
    The rendering is basic but it lets you see all the different surfaces.
    Ji
    Grip it and Rip it
