Results 1 to 3 of 3
    Jan 2008
    12
    Default xmt 304 TIG setup
    Hello, I'd like to do some simple aluminum TIG welding with this. Can anyone recommend an inexpensive setup for the 304 to get me started? I'm assuming the shielding gas connects to a fitting right at the power lead connection at the 304. I'm new at this.
    Dec 2005
    Dallas, TX area
    267
    Default XMT304/Aluminum
    You can't tig weld aluminum with an XMT304. Tigging aluminum requires high frequency AC. The XMT is DC only as I recall.
    Good luck with that.
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    Alaska
    732
    Quote Originally Posted by triggerman View Post
    That is not true.
    AC is not required to GTAW weld aluminum nor is a high frequency generator.
    Please do your homework and report back later tonight with how you are wrong.
