    May 2008
    Troy, MI
    361
    Default Brackets for Railing
    I welded four rail brackets for a friend at work. The brackets attach a rail system to the side of the wooden steps. They were necessary to allow the railing on the steps to line up with the railing on the deck, while preserving as much space on the deck as possible. In picture one you see a SolidWorks model showing how the system works. The blue bracket is the one that I welded. It attaches to a pipe that supports the post of the rail system.
    Picture 2 to 4 are pictures of my welds.
    Pictures 5 and 6 show mounting hardware before the post was installed.
    Pictures 7 & 8 show the finished railing.
    I thought that my friends railing job came out real nice.
    Miller Thunderbolt
    Smith Oxyacetylene Torch
    Miller Dynasty 200DX
    Lincoln SP-250 MIG Welder
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    May 2008
    Troy, MI
    361
    The rest of the pictures.
    Miller Thunderbolt
    16" DuAll Saw
    15" Drill Press
    20 Ton Arbor Press
    Bridgeport
    3,950
    Nice job...Bob
    Jun 2011
    Yeah i have also seen led retrofit that all images they have done really great work !.
