Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
    May 2009
    Central North Carolina
    133
    You may need a hinge on the chimney. That last picture looks like the chimney is taller than the door behind it. Oops !! (I hope I'm wrong).
    I haven't seen any square smokers on trailers before. This is interesting. Please keep the pictures coming.
    Charley
    ______________________________
    Miller MM252
    Miller Bobcat 225NT
    Miller DialArc HF & DIY Cooler
    2 Miller Digital Elite and 3 Fixed Shade Helmets
    2 O/A torch sets
    DeWalt 18 volt 1/2" Driver/Drill
    DeWalt 18 volt 6 1/2" Metal Saw
    DeWalt Porta Band & SWAG Offroad V3 Table
    Milwaukee 8" Dry Cut Saw
    Milwaukee 14" Dry Cut Chop Saw / Delta Stand
    Milwaukee 9" Grinder
    2 Milwaukee 4 1/2" Grinders
    Milwaukee Hole Hawg 1/2" Drill
    Wallace 5 Ton Gantry
    Too many hand tools
    Interesting design. How does the smoke enter the upright chamber?
    Dec 2010
    206
    have you given thought to where your weight is being distributed ?it looks like you got alot of the weght on the rear of the trailer and that may result in some swaying going down the highway.
  4. #14
    Aug 2011
    1
    It looks like you are doing a reverse flow design, but I have a couple of questions for you: I don't see any kind of lip or stop to keep the grease draining back into the firebox and I don't see any type of drain to get the grease out of the main pit area. Just a thought.
    Someone else had mentioned the pit calculator earlier and this is the link that I used to build mine and it worked great.
    http://www.feldoncentral.com/bbqcalculator.html
    The pit looks great so far!
