Results 1 to 10 of 14
    Jun 2011
    11
    Default Vertical welding Aluminium with TIG, is it possible? how?
    Regards
    Marcelo
    Oct 2008
    Edmonton, Alberta
    89
    Yes it is. Vertical up. Practice.
    "When the wise old rooster crows, the smart young rooster listens."
    Oklahoma
    738
    Quote Originally Posted by lw3eov View Post
    Regards
    Marcelo
    Yes it is possible. As Jason said, practice.
    Griff
    4,494
    Practice is a slow way to learn, but it is more than possible, some of the worlds finest welding is done vert, overhead too.
    Jul 2008
    East Tennessee
    615
    I prefer to make corner welds on aluminum going up hill.Remeber heat rises and I think it helps me.
    Dynasty 200DX "Blue Lightning"
    Bernard 3500ss water-cooler
    Rockwell vertical mill
    Beverly Shear B-3
    Beverly Shear JR
    Home-made English wheel
    Milwaukee Porta-band
    " Sawz-all
    Tennsmith 36" stomp shear
    Fixer upper 1968 Redface Lincoln sa200
    Powcon 300st
    Jan 2007
    South Carolina, Dixie
    515
    Smile Uphill TIG
    You bet it can be done. Puddle up , add the rod and move As you move let the amps slide off a bit and let the puddle freeze. Then amp back up and add rod, Repeat the sequence. Practice. Time under the hood. Just you and the metal.
    Practice in some 1/8" stuff and work up to heavier materials. Actually you can add filler rod from either the from or back side of the torch. Just takes a little time to get the hang of it. It will help you a lot if you can find an instructor ar even a good "ol' TIG Master that could show you a couple of times. Amazing what a qualified instructor can help you achieve!
    Mustangs Forever!
    Miller equipment.
    Oklahoma
    738
    Quote Originally Posted by Sberry View Post
    Just curious. What might be a "fast" way of learning?
    Griff
    4,494
    Fast way is to get an expert to learn from. I went to a seminar get together with the SFT gang a few yrs ago, the whole trip was good but it was worth it alone to see Chris from Miller sitting at the bench giving demo on a 200 Dyn. Learn more in 45 minutes watching his demo routine than I could have in a month or maybe even ever by simple trial and error. I am still not any good and could care less for the most part but could pick it up and be passable in short order, if I had a real hardon to be a tigger I would get to a class or find someone who really knew to give some coaching.
    Jun 2011
    11
    Default How do you avoid the melted AL from the rod dropping to the floor?
    Thanks for the answers. How do you avoid the melted AL from the rod dropping to the floor?
    The machine we have is Tauro, probably not know in Europe or the US. It's a 3000 dollars machine, however it doesn't come with a foot pedal to regulate the amps, just a knob
    I am in Argentina now, where I am from, and there are no TIG AL courses available, only steel and there are full for months + they cost far too much. In this town, there are only 3 guys who use TIG and they can't do it vertically so there is no one to ask.
    I live in the United Kingdom, where I will return in October, but again, the courses cost a lot of money and I am not interested in spending that amounts to become a pro welder, I just want to learn the techniques so I can add up some more skills which I think will help me in my electro-mechanical prototypes making tasks.
    Thanks. Regards.
    Marcelo
    Sep 2009
    Key Largo, FL
    24
    Default Al dropping
    Marcello,
    The filler rod is not supposed to drop on the floor. Start from the bottom on an inside corner. I mean 90 degress. Get a nice shiny puddle with just a minor point up of the tig rod.
    When nice and shiny dip the rod in from the top. Keep your cup (i use a #6 or 7) on the metal and just keep coming straight up adding rod. I'm talking 1/8" material 2" x 2" tubing (6063) t6 I think, at 165 amps with a Dynasty 200 DX, Bal 70, freq 135.
    3/32" diamater 1.5% lantanated tunsten to a point, flush to the cup, 25 cfh argon.
    I make my best welds this way.
    Good luck,
    Gary
Tags for this Thread
