    Jun 2011
    Default 1 to 3 foot diameter rings
    I am a beginning art welder. I need to figure out how to make or where to buy steel rings 1 to 3 feet in diameter rings from 1 to 2 inch tube or solid stock. I have a 16 ton tube bender but it will only bend to 90 degrees. Yes, I could make 4 90Degree bends and weld them together, but there must be a better way that would not have 4 welds
    3,954
    You need a ring roller to do those or find someone close that has one and have them roll you a few...Bob
    Feb 2008
    miami
    262
    i've used these people a lot over the years. they can provide most anything you need.
    http://www.wagnercompanies.com/site/...ticle&rpid=553
    this is a link to the elbow site. go to the home page and contact customer service.
    if you are into doing one/offs it's better to pay and use someone elses machines rather than have something sitting around collecting dust. just pay and mark it up.
    i have made rings buy buying two 180's/no extension and welding them together.
    if it's angle, look for a company that sells companion flanges for round pipe. sheet metal blowpipe.
    not near you
    148
    Harbor freight has a roller for pipe/rod that sells for around 150..
Tags for this Thread
