    Jun 2011
    Default Fillet Size Calculation
    Hi...
    I am designing for 20mm with 25mm T-joint. what will be the throat size? and how much load that particular weld area can carry? bcoz i will lift the job with over hoist. wt of the job will be 2 ton...
    Can any one help me?
    4,446
    How long is this joint? On plate that thick it wont need a lot for that weight, usually 3/8 or 1/2 but there are other factors.
    Jun 2011
    First of all many thanks
    I am using rectanguler block of 80 X 80 X 20mm thk.. Weld all around. Sir..is there any standard formula for calculating leg length and throat thickness.
    1. Z = a x sqrt 2
    2. .707 x t = Leg length
    These formula i know but i refer so many drgs but all the time i am getting different sizes of weld.
    Feb 2006
    3,711
    http://www.welding-technology-machin...-thickness.htm
    This website may help. Look down the left hand column for joint design, etc.
    Good Luck,
    HAWK
    We really need a photo or a drawing.
    Welds in shear ??
    In general If a rod is E7018 it means 70,000 lbs tensile strength PER INCH.
    You need a set of welding inspection guages for measuring the throat of a weld.
    The width of a weld is about two rods wide with the flux coating on.
    There are other factors.
    Never stand under ANY load being lifted.
