Thread: DC Polarity
    Default DC Polarity
    What are the main differences in actual welding between, Straight Polarity
    (electrode -) and Reverse Polarity (electrode +).
    Jan 2008
    philadelphia,pa
    5
    i am a student and we have just learned about that and basically it differs from which welding process your doing for example tig the heats shoots right up through the electrode when your welding with striaght polarity but that is what my teacher was telling us!!
    Dec 2005
    Dallas, TX area
    267
    Default Main difference
    Reverse polarity, DCEP, promotes more penetration
    Straight polarity, DCEN, promotes mild penetration
    (A/C is somewhere in between.)
    Hope this helps.
    Triggerman
    Ammonia refrigeration tech
    Millermatic 180 w/Autoset
    CST-250
    HF-15 High frequency
    XR15 w/Push-Pull Gun
    Thanks Triggerman, a very helpful answer.
    Fraser Valley, BC
    593
    I depends on what process you are using. With Tig, DCEN is used for welding ferrous metals, while AC is used for welding most non ferrous metals such as Aluminum
    With GMAW, DCEP is the only polarity that can be used. With Fluxcore wires, the polarity will depend on what type of wire is being used.
    With SMAW, various rods use different polarities. In general however, rods run on DCEP provide more penetration while those run in DCEN provide less. However, this is just as much a case of the type of flux used on the rods as the polarity.
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
