Page 5 of 8 FirstFirst 12345678 LastLast
Results 41 to 50 of 74
  1. #41
    aluminum seems to eat up the filler. its less a dip and more of a push in some. i keep 3/32 and 1/8" the 3/32 is my fav.
    for realy little stuff i have some aluminum MIG wire.
  2. #42
    Lightbulb
    do your best to keep it coverd also. from what i have heard the thing is packed way to full to be popping open to blow out. a cover will drastically reduce the amount of crap to accumulate inside it. just look at all the junk in the air wile grinding and sanding. after the first time i opened my MM135 to blow it out i started using a cover and it made a huge difference keeping it coverd when not in use.
    i'm planing on mt TA's 2nd or 3rd birth day (with me) to take it in to have it cleaned out by the service guys. to much $$ invested to risk a bo-bo over a $60 service fee.
  3. #43
    Jan 2008
    Most likely in Florida
    111
    Roger wilco. Sounds like good advice. Thanks.
  4. #44
    i like to keep my filler the same size as my tung. or close
    you will find the 3/32 to be the most used size in tung. as such 3/32" & 1/8" filler are most often used. however in a pinch use what ya have. i have twisted several pieces of the MIG wire together to get a size that worked when out of 3/32" filler. gotta do what ya gotta do.
  5. #45
    Jan 2008
    Colorado
    673
    Quote Originally Posted by root View Post
    I also ordered some 1/16" aluminum rod since it matches roughly what I will be tinkering with. Maybe I should also pick up some 3/32" it sounds like? Why would the 3/32" be easier to weld with than the 1/16"?
    The idea in TIG is to melt a puddle, then dip your filler in that puddle. Dip, dip, dip, dip at about 1/2 second intervals. At my skill level, 1/16" rod will melt before you get it to the puddle. And by the time this happens, you'll have a melted hole in your 16ga. 3/32" has the mass to last long enough to get to the puddle. Don't forget, your arc length is only 1/8", this is very tight quarters. You're holding the rod about 8" to 10" from the end, it's wobbling and you've got an 1/8" target you're poking at (NOT THE ARC, next to it in the puddle). And, with every poke, your rod gets shorter. If ya poke the tungsten, guit, you're done. Nothing gets hurt, but the alum rod wicks onto the tung, turns your arc green, flashes a big black poof and contaminates any further weld. Regrind the tung to remove the alum blob, clean the 5" circle of ugly black soot off your project, and continue. Hand grinding is just fine, you don't need anything special. I use a 6" grinder with a fine regular wheel. A bench belt sander works too.
    OK, yer into me for $500. This is fun. How many more questions ya got??
    RETIRED desk jockey.
    Miller Syncrowave 250.
  6. #46
    Queens NY
    1,547
    generally speaking i don't dip the rod when doing aluminum. i swipe the tip across the puddle at a very low angle. This seems to help avoid tung contamination and melting of the rod before it gets to the puddle. Its more of a circular motion than a back and forth. i find it much easier then dipping in and out.
  7. #47
    Jan 2008
    Colorado
    673
    Thumbs up
    Laiky: Thanks for joining in. As I've found, you can't say something without getting questions.
    Being self taught, tricks are hard to come by.
    Down, toward you, through the puddle?
    Or, up, away from you?
    Are you able to scratch it along the base metal, thru the puddle? This would help me stop the wobbling.
    PS OK, it's after midnight and I just saw this:
    "Its more of a circular motion than a back and forth."
  8. #48
    Craig in Denver well put. it all looks so easy till you try to juggle it all at once, did you mention you are also working the foot peddle during all this to try to control the heat.
    i tend to tweak my torch back as i slid in the filler from the front.
    touching the filler to the work is fine, helps you get to the leading edge of the puddle before it melts. if you keep the filler at the front edge its in the gas flow but not so much heat as to melt away. you can also lay the filler over the joint and run the torch over it melting the filler into the joint. this makes thin stuff essayer as there is more mas for the arc to melt, making melt threw less likely. keep in mind you still have to make shore you get enough heat to melt the base metal or you are just melting filler on the joint, not a good thing. so be shore to keep the heat up and a large enough puddle to fuse the joint.
    a copper backing plate is helpful also, never tried it but its a good plan.
  9. #49
    Jan 2008
    111
    Quote Originally Posted by Craig in Denver View Post
    Sorry. I think Laiky gets the $500. Thanks for playing.
    Excellent information from everybody. Very much appreciated.
  10. #50
    Jan 2008
    Colorado
    673
    Unhappy
    Oh, I forgot about the pedal.
