Results 1 to 7 of 7
    Jul 2009
    New York New York
    30
    Default what is the best way to weld this
    I have an exhausting system replacing the factory cat with high flow cat... the flanges have sleeves, it slips right over the cutted downpipe where the cat used to attached to... it has a little rust, it is steel / aluminuzed steel ? the sleeve over is stainless.... since it fitted over with a little gap. between old a little rust and new pipe. what is the best process , recommendations ?
    I have acess: Mig with carbon steel / flux or gassed. or Tig dynasty 200DX with 309L 308L or carbon wires , or silicon rods ?
    Dec 2008
    Arizona
    804
    Since you are dealing with stainless and aluminized (as well as used/contaminated) steel, I'd use one of these: http://www.summitracing.com/parts/WLK-33226/
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    Jun 2010
    Indianapolis Indiana
    200
    If you want it pretty, tig it with some 308 rod. If you want it done fast, mig it with some carbon steel and 75/25.
    Miller 330 BPA - Sold
    Miller 180SD Syncrowave - Sold
    Miller Aircrafter 330ST - Sold
    Miller 351 Syncrowave - Sold
    Miller CP-300
    Miller Maxstar 150 STL
    Miller Dynasty 200 DX
    Miller 135 Millermatic
    Miller Spectrum 250D (Now running strong!)
    Jul 2009
    New York New York
    30
    Thanks Guys, I would try the band clamp but it is close right at the bend ...
    so tig / mig might be the only way to go....... do I have to clean off the rust / scales from the original pipe or would the welding process cleans it up ??
    Feb 2007
    asheville n.c.
    595
    Try to always clean prior to welding. Too much garbage can stay in the welld and weaken.
    Jan 2011
    Nolalu (near Thunder Bay) Ontario, Canada
    41
    Quote Originally Posted by dogdog View Post
    If you have to ask then . . . I'll get the popcorn
    Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
    Jul 2011
    162
    The aluminum here is the killing agent in the steel and/or a corrosion prevention coating. Aluminum killed steels weld just fine, only difference is the aluminum oxide won't melt in the weld and form a tiny slag bead like silicon killed steels. And Al killed steels are finer grain with slightly better corrosion resistance.
    Aluminized steel has a mechanically-applied coating of aluminum which acts like the zinc coating in galvanized steel. Only aluminum won't vaporize as easily, zinc will rapidly degrade/vaporize under exhaust heat.
    Metal fume issues are not present with aluminized steels don't have the dangers of galvanized/zinc coated products, most weldable primers like Deoxaluminite are aluminum based.
    Finally, killed steel refers to the lack of free oxygen in the final mill product. Steel is borne from the basic oxygen process which takes molten cast iron (4%+ carbon dissolved in iron) and bubbles oxygen through it to burn out the carbon. This leaves the iron with less than 1% carbon but it also fizzes like a soft drink since residual oxygen and carbon monoxide are present. Silicon, aluminum and or manganese are added which strongly combine with the oxygen and carbon monoxide, making the steel "quiet" or "killed". If you have ever welded mystery steel which bubbles, pops and causes issues even when perfectly clean, that is probably non-killed steel. It is frustrating, especially with sheet products.
