I have an exhausting system replacing the factory cat with high flow cat... the flanges have sleeves, it slips right over the cutted downpipe where the cat used to attached to... it has a little rust, it is steel / aluminuzed steel ? the sleeve over is stainless.... since it fitted over with a little gap. between old a little rust and new pipe. what is the best process , recommendations ?
I have acess: Mig with carbon steel / flux or gassed. or Tig dynasty 200DX with 309L 308L or carbon wires , or silicon rods ?
Results 1 to 7 of 7
06-07-2011, 02:23 PM #1
- Jul 2009
- New York New York
- 30
what is the best way to weld this
06-07-2011, 08:12 PM #2
Since you are dealing with stainless and aluminized (as well as used/contaminated) steel, I'd use one of these: http://www.summitracing.com/parts/WLK-33226/
Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
06-07-2011, 10:15 PM #3
- Jun 2010
- Indianapolis Indiana
- 200
If you want it pretty, tig it with some 308 rod. If you want it done fast, mig it with some carbon steel and 75/25.
Miller 330 BPA - Sold
Miller 180SD Syncrowave - Sold
Miller Aircrafter 330ST - Sold
Miller 351 Syncrowave - Sold
Miller CP-300
Miller Maxstar 150 STL
Miller Dynasty 200 DX
Miller 135 Millermatic
Miller Spectrum 250D (Now running strong!)
06-08-2011, 08:13 AM #4
- Jul 2009
- New York New York
- 30
Thanks Guys, I would try the band clamp but it is close right at the bend ...
so tig / mig might be the only way to go....... do I have to clean off the rust / scales from the original pipe or would the welding process cleans it up ??
08-07-2011, 07:25 PM #5
- Feb 2007
- asheville n.c.
- 595
Try to always clean prior to welding. Too much garbage can stay in the welld and weaken.
08-08-2011, 06:06 AM #6
- Jan 2011
- Nolalu (near Thunder Bay) Ontario, Canada
- 41
08-22-2011, 11:26 AM #7
- Jul 2011
- 162
The aluminum here is the killing agent in the steel and/or a corrosion prevention coating. Aluminum killed steels weld just fine, only difference is the aluminum oxide won't melt in the weld and form a tiny slag bead like silicon killed steels. And Al killed steels are finer grain with slightly better corrosion resistance.
Aluminized steel has a mechanically-applied coating of aluminum which acts like the zinc coating in galvanized steel. Only aluminum won't vaporize as easily, zinc will rapidly degrade/vaporize under exhaust heat.
Metal fume issues are not present with aluminized steels don't have the dangers of galvanized/zinc coated products, most weldable primers like Deoxaluminite are aluminum based.
Finally, killed steel refers to the lack of free oxygen in the final mill product. Steel is borne from the basic oxygen process which takes molten cast iron (4%+ carbon dissolved in iron) and bubbles oxygen through it to burn out the carbon. This leaves the iron with less than 1% carbon but it also fizzes like a soft drink since residual oxygen and carbon monoxide are present. Silicon, aluminum and or manganese are added which strongly combine with the oxygen and carbon monoxide, making the steel "quiet" or "killed". If you have ever welded mystery steel which bubbles, pops and causes issues even when perfectly clean, that is probably non-killed steel. It is frustrating, especially with sheet products.
