Results 1 to 9 of 9
    Scottsdale, AZ
    173
    Default Welder tip shape
    For you experienced pros in welding:
    My buddy has several tips [the brass push on/off piece that covers the copper electrode] that is has ground down at about 45 degree angles. Some have 1 45 degree angle and some have 2. He tells me these are for welding corners and places where the full cone shaped head cannot get into. He has a MM 252.
    He is not a professional welder, just a home user.
    I have a few folks about this and no one seems to know one way or another if this makes good welding sense.
    What do you guys think????
    Don
    Scottsdale, AZ
    www.savagesun4x4.com
    MillerMatic 211 AS
    Hypertherm PowerMax30
    Bernard 300 Amp Q Gun
    Bernard 200 Amp Q Gun
    Milwaukee Band-saw/stand
    10 Angle Grinders 8, 4 1/2" -2, 7"
    DeWalt Chop Saw
    Craftsman Twin-Blade Saw
    12 Ton Shop Press
    Optrel Satellite Helmet
    Miller Elite Helmet
    Aug 2007
    Seattle,WA
    55
    why would the tip be sticking out farther than the nozzle? I don't understand how the tip would get in the way, are you talking about the nozzle?
    Welders do it hotter!!
    www.Munsonworks.com
    Nov 2007
    West Georgia
    103
    Default angle ground into nozzle
    Amateur musings...
    Biggest problem is that -- if you get into the corners closer than the regular nozzle would allow -- how are you going to see what you are doing? Welding inside corners and angles isn't all that difficult with a regular nozzle.
    Scottsdale, AZ
    173
    Quote Originally Posted by Clavacle View Post
    NOZZLE was the word I was looking for. He grinds 1 and both sides down to fit into tight spaces such as right angles etc.
    Don
    Scottsdale, AZ
    MillerMatic 211 AS
    DeWalt Chop Saw
    12 Ton Shop Press
    Miller Elite Helmet
    Scottsdale, AZ
    173
    Quote Originally Posted by EdZep View Post
    Amateur musings...
    Seems to me there would also be a shielding gas problem???
    Don
    Scottsdale, AZ
    MillerMatic 211 AS
    DeWalt Chop Saw
    12 Ton Shop Press
    Miller Elite Helmet
    Mar 2007
    Fraser Valley, BC
    593
    I have a couple of nozzles in my tool box at work for getting into hard to reach places. Nothing fancy, just some love with the belt sander and a die grinder. Only use them for tight places that are unweldable normally, switch back to a normal tip when I'm done.
    Makita 5" grinder
    Makita 14" abrasive saw
    IR SS5L compressor
    and a wish list a mile long
    Aug 2006
    near rochester NY
    9,881
    actualy, they make similer tips for spot welding with MIG. they make one for flat, inside corner and outside corner.
    i can get you a pic if you want.
    Scottsdale, AZ
    173
    Quote Originally Posted by fun4now View Post
    I have seen those, thanks...
    Don
    Scottsdale, AZ
    MillerMatic 211 AS
    DeWalt Chop Saw
    12 Ton Shop Press
    Miller Elite Helmet
    Dec 2006
    Alaska
    732
    Default Amateur musings: poke a stick in his eye why don't ya?
    Amateur musings...
    Yes; Ed Zap your musings are amateurish.
    One need not all ways see the arc to produce a fine weld, especially with wire feed welding, as the sound of the weld as well as the reflected light can usually guide a proficient welder.
    Many a fine weld has been produced with the contact tip extended well past the end of the gas nozzle. A small amount of purged gas to expel the atmosphere, strike the arc and listen to what you are doing.
    I as well have several custom shaped gas nozzles and a few custom bent contact tips to go with.
    What ever it takes to get comfortable with the job at hand, to produce the best weld at the time.
    So amateurs muse away, you never know who will come up with the next great idea.
    TJ______________________________________
