Results 1 to 10 of 12
    Dec 2010
    Default Syncrowave DX or Dynasty
    Which pulsed tig machine is the better choise for light aluminum fab work?
    Baldwin, NY
    275
    Dynasty, not even a close comparison....
    Voigt Precision Welding, Inc.
    Miller Dynasty 200 DX, Miller Syncrowave 250, MillerMatic 252, Hypertherm Powermax 45, Auto Arc Trailpower 8000,272+187 lb Peter Wright anvil, 120 lb Fisher-norris, and more! Buffalo drill press, Grizzly Horiz. Bandsaw, Edwards shear, Barth Shear, bantam mechanical ironworker, Hopkins fly press, Doall Bandsaw, brown and sharpe surface grinder.
    2007 Silverado 2500HD (tow vehicle)
    2000 Camaro SS (Race car)
    canada
    65
    Amen Dynasty rocks
    Utah
    162
    If the pulse feature is all that you are after then either machine will work. It is all of the other advanced squarewave features of the Dynasty that make it a bettery choice overall.
    We have a Synchrowave 250 at work that welds great and is a real workhorse. I have a Dynasty 300 at home and it welds great as well but with more adjustability. On the thin stuff you can pulse, soften the arc, widen the arc by changing the balance and on the thicker items you can create more arc force as well as make the weld dig in deeper.
    Mike.
    23
    Quote Originally Posted by zmotorsports View Post
    Mike.
    Very good response!
    Nov 2008
    Colorado Springs
    272
    Default Cost must be considered
    I don't know it the OP is a company or using this for home garage work.
    So the budget is a consideration for any purchase.
    The Sync might be a bit cheaper up front than the Dynasty.
    The Sync will cost more to run every month than a comparable Dynasty model.
    Both will do the job described and much more. What monthly profit margins are you wanting to achieve.
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    Hypertherm PowerMax 1000
    20" x 40" CNC Mills (2)
    16" x 60" engine lathe
    65 Ton edwards iron worker
    3/16' x 24" power slip roll
    16' power feed mitering bandsaw
    and other fun toys
    Maryland
    699
    Default Dynasty 200
    Just have to add.
    The Dynasty 200 is portable and runs on 110V in a pinch. Need to drag it to a friends house? The Dynasty is the only way to go.
    If you ever have to do thick aluminum (thicker than say 1/4"), fill that gap with a MIG setup.
    The Dynasty 200 will do 100% of all the TIG welding you will ever have to do on a car.
    The only bad thing, if you hit Craigslist etc. you can sometimes find Synchrowaves for $1400 or so. I have yet to see a Dynasty 200DX for less that $2200 - even old, non blue lightning version.
    Priced new, they are both in the same ballpark. With the 250 you really need factor in the water cooled torch and cooler.
    With the 200, it depends on how much welding you will do. Quick jobs (most around a car are) don't really require water cooled.
    Con Fuse!
    Miller Dynasty 350
    Millermatic 350P
    -Spoolmatic 30A
    Hypertherm PowerMax 1000G3
    Miller Multimatic 200 - awesome portable MIG (and stick and TIG)
    Miller Maxstar 200DX - portable TIG and stick
    Jul 2011
    Smile Newby question
    I was considering a Syncrowave 200 Runner. Now, I see members saying the Dynasty is a better machine. I have priced the Syncrowave @ $2700 vs. the Dynasty @ $ 4500. Not to sound like a smart a$$ but I would hope with that price difference it would be better. I realise many members are full time professional welders and in no way do I intend or mean to question their knowledge! I am just asking if the Syncrowave can do a nice job welding up to 1/4" Alum. I am a retired/amateur that wants a reliable machine that can do a nice job. I am not in a hurry so duty cycle is not a big concern. I appreciate any and all suggestions. Thanks, Jimmy
    Near Dallas, TX
    214
    I bought the Dynasty200. At times I wish I'd bought the sync250. The dynasty is a great machine, but I could always use more power/duty cycle. I'm working out of the shop most of the time so the weight on the sync isn't that much of an issue. One time I carried the dynasty out and did some stick welding on 110v. That was nice! You could probably buy the sync AND buy a little inverter DC stick machine for the same money as the dynasty.
    Dynasty200DX w/coolmate1
    MM210
    MM Vintage
    Lincoln AC225
    Victor O/A, Smith AW1A
    Cutmaster 81
    IR 2475N7.5FP
    Evolution Rage3
    Jancy USA101
    9" South Bend
    AEAD-200LE
    We have both at the shop and the dynasty is always the machine taken first. If your just a hobbyist then truthfully a used sync 180 or 200 will do just fine. Those can be found used for around $1500 all day long.
