I have a miller elite digital welding shield and find myself needing to use a cheater lens. The Manuel boasts of convinute magnifying lens holder. the problem I'm having is due to the cheater lens mount being too narrow for the lens I've found and it mounts the lens .125' or so from the inside cover lens, .125 gap between, allowing condensation/fogging between cheater and inside cover lens. Is there a cheater lens designed for this helmet? thanks.
Results 1 to 10 of 13
05-15-2011, 11:06 PM #1
Miller Elite Digital Hood and Cheater Lens?
Miller TrailBlazer 251NT
Miller HF-250-1
Miller Maxstar 150slt
Miller ft peddles and thumb wheels
Miller MM 212
Lincoln power mig180c (two of)
MM 252
Miller Elite Dig
Miller Pro-Hobby
05-16-2011, 12:08 AM #2
- Apr 2009
- Sands Twp, Marquette Co, MI
- 32
I will never understand why people call call them cheater lenses. I think they should be called helper lenses. Anyway Miller does make helper lenses (http://www.millerwelds.com/products/...ccessories.pdf).
I have only welded in dry locations and am usually calm, cool and collected, but it seems to me that I have noticed a little condensation on occasion. I do like my helmet a great deal. When I first purchased it it seemed awfully flimsy to me, but it is holding together well, and I like the light weight.Last edited by smfcpacfp; 05-16-2011 at 12:12 AM.
05-16-2011, 06:12 AM #3
- Jan 2011
- Nolalu (near Thunder Bay) Ontario, Canada
- 41
Mine mounts a plastic cheater nicely. Not sure if it can accommodate a glass lens (haven't tried).
I don't get any more problems with it than I do with my Fibermetal Tigerhood.Gordie -- "I believe you understand what you think I said, but I'm not sure you realize that what you heard is not what I meant."
05-16-2011, 11:04 AM #4
- May 2009
- Central North Carolina
- 133
I've been using a digital elite for about 2 years now with Miller's plastic cheater lens in it. I use an anti-fog from the drug store that's intended for eye glasses. It seems to work pretty good, but I think it's mostly just glycerin.
Other than needing to remove the lens to clean both it and the inside face of the auto-dark lens and then re-apply the anti-fog I haven't needed to do any maintenance to it. Your cheater lens must not be the one that is supposed to be used with the digital elite.
Charley______________________________
Miller MM252
Miller Bobcat 225NT
2 O/A torch sets
Milwaukee 8" Dry Cut Saw
Milwaukee 9" Grinder
2 Milwaukee 4 1/2" Grinders
Wallace 5 Ton Gantry
Too many hand tools
05-16-2011, 09:08 PM #5
- Nov 2010
- Central Kalifornia
- 63
Cheaters
When I bought the Digital Elite I ordered the "cheater" made for the helmet. I get no condensation and the lens is easy to install and remove. Makes cleaning a snap. Don't use a towel on the lens, get something real soft, otherwise you will scratch the lens and have to replace it, just like I had to do.
05-16-2011, 09:57 PM #6
Miller HF-250-1
Miller MM 212
MM 252
Miller Elite Dig
Miller Pro-Hobby
05-16-2011, 09:58 PM #7
Miller HF-250-1
Miller MM 212
MM 252
Miller Elite Dig
Miller Pro-Hobby
05-16-2011, 10:34 PM #8
- Sep 2008
- Estevan, Sask
- 111
I just use a normal glass cheater with plastic frame in mine for the past year and a half or so. It`s a little snug to get in but it never moves
Glass seems to last longer than plastic for me cause they don`t get scratched up.Tried a Miller brand the first time but since they cost more and don`t fill the oversize window, I didn`t buy any more of them. What is the sense of making the large window and only supplying small cheaters that don`t allow you to take advantage of the window size?! Sounds like some brain wave an engineer would come up with
05-17-2011, 09:01 AM #9
- Jan 2008
- 6
I have a Miller elite Have been using plastic Cheaters Lenses But every time I raise my helmet I have to put my glasses on So readjusted headgear forward now I can use my wearing cheaters
05-17-2011, 05:12 PM #10
Best "Cheaters"
I've used these for years:
They are better than the inserts in your hood cause you still have safety glasses on when you flip your hood up and you can still see clearly. They are very comfortable, durable and offer great protection. I can't recommend them highly enough.Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
