Results 1 to 10 of 13
    Nov 2010
    Michigan
    34
    Default Electric Catamaran conversion
    Hay guys .. been a while since i have been here .
    I have been working on two boat projects .
    built a mini pontoon a few years back for our small no gas motor lake .. had som plastic chairs on it ..but they had to go .. I bought a pipe bender from harbor freight to play with and things got started .
    I also bought the parts to build and convert a peddle powered catamaran to elect drive .
    If it dosent have a motor i dont want it .. lol
    the catamaran is almost done .. still needs a luggage rack on the back for coolers and and such .
    the original unit had 2 peddle drive systems on the front and with them removed there was no place to put your feet or stand ,
    here are some pics of both
    enjoy Don
    2,636
    Nice!!!
    Jul 2009
    Australia
    980
    Stupendous !
    Are these floating devices for fishing ?
    Ji
    Grip it and Rip it
    Nov 2010
    Michigan
    34
    yes the intent may be to fish .. or chase girls around the lake .. lol
    I just like to think out side the box sometimes .
    It needs the umbrella or palm tree. Right?
    May 2011
    Bossier Parish La.
    385
    Default shade
    Some type of retractable sun shade might make a nice addition to the aluminum rig. It could be incorporated into the "luggage rack" you mentioned for the beverage cooler. That might be welcome if you've spent too many days in the sun and "Red Skin Syndrome" has set in but you still want to get out on the water. You may want to look into adding a solar battery charging system too. Northern Tools has some, this may keep you from having to remember to charge the battery after every use, and also make your battery live longer.(fewer replacements)
    Nov 2010
    Michigan
    34
    I started working on the luggage rack .. need to find a bakini top from a boat thet will fit it .
    I like the idea of a solar charger ..good idea
    thanks Don
    May 2011
    Bossier Parish La.
    385
    You should be able to fabricate the frame for the top your self, then have an upholstery shop or awning company make the covering material to fit it. This may be better than trying to find one to fit such a small craft. No telling how long you may have to search to find something close to fitting since most boats with that kind of top are much wider. Hoping to find something close, may still need modifying to work and would still be a comprimise to what you actually like. An upholstery shop or awning shop could give you a choice in colors or patterns in the coverings as well. An awning co. may be able to make suggestions on how to build the frame if you check with them first. Some of them have experience making covers for boats. Cutting and bending the tubing and making mounting brackets should be pretty simple to do(after seeing what you did building those motorcycle trailers, nice work on those too). Hope this helps get you what you want sooner.
    May 2009
    The Colorado Gas Patch
    184
    Default Let There B Shade
    Check out this site for some ideas:
    http://www.riversombrero.com/collections/all-products
    Steve
    Bobcat 250EFI
    Millermatic 350P
    Hypertherm 1250
    A Bunch of tools
    And a forklift to move the heavy stuff with..
    Looking at CNC Plasmas
    It's Miller Time - Get Back To Work!
    Jun 2009
    greenfield new hampshire
    777
    don,t forget to leave some room for the pink flamingos
