I purchased a commercial wheel truing jig some time ago when I was restoring some vintage dirt bikes and it worked great. Recently I had to respoke a modern rear wheel and the jig was too small.
The wheel needs to be trued so I had to fabricate a truing jig that can handle all wheels.
Today I ordered and picked up all the aluminium sections needed for the job.
Material including cutting cost $24.00.
I had to lathe and cut a 3/4" UNC thread into the solid round bar.
Ji
Results 1 to 10 of 19
Thread: Dirt Bike Wheel Truing Jig
05-10-2011, 06:34 AM #1
Grip it and Rip it
05-10-2011, 06:39 AM #2
I drilled out a 1" hole in the box section to recieve the threaded rod axles.
So the threaded rod axles line up I clamped it all together while I tacked it.
I am not the best at welding small diameter tube fillet welds so you will all have to cut me some slack on the welds.
JiGrip it and Rip it
05-10-2011, 06:40 AM #3
Then it was just clamp, wire brush and TIG weld.
05-10-2011, 07:55 AM #4
Nice work and pics...Bob
05-10-2011, 07:12 PM #5
Thanks for the kind words Bob.
05-10-2011, 07:19 PM #6
I then countersunk some hidden screws to hold the telescopic legs followed by fitting some height adjustable feet.
05-10-2011, 07:25 PM #7
Then I decided to go fancy with the handle and make a S/S hand wheel.
I used a bar bender to get two 180 degree 8mm diameter bars.
If done right they should just about make a perfect circle when cut and welded.
A hole was drilled into the threaded rod and another 8mm S/S bar was taped into position.
Then all the hand wheel parts were TIG welded together.
05-10-2011, 07:29 PM #8
Time for a test.
The truer can hold a modern rear wheel no problems.
I gave mine extra depth and width so I can true a wheel even with the tyre still on the rim.
This is a rear wheel with is 19" diameter while a front wheel is 21" diameter.
Very pleased with the results now I can start truing that wheel so we can be riding again this weekend.
05-11-2011, 06:56 AM #9
- Nov 2009
- houston pa
- 101
looks good and you pocketed a lot of cash over buying a new one.
05-11-2011, 04:00 PM #10
Nice work!
