Great design, I really like it.
I esp. like the pins for holding the bottle caps. Neat idea.
You need a place to keep your spare tips. attachments, and striker, though.
I have two of the Harper carts for my tanks. They're too expensive new, but I got them used. They're downright cheap looking and feeling compared to yours.
Now, go get it dirty.
-James
Results 11 to 20 of 24
01-26-2008, 07:52 AM #11
- Mar 2007
- 132
01-26-2008, 08:38 AM #12
- Nov 2007
- West Georgia
- 103
Many thanks
It's nice to hear good things from others.
I have no drawings, Steve. But, I sort of wish I'd kept the 3-inch Post-It with my original sketch. It would be kind of funny to scan and post.
I first decided how big the foot-plate would be. Then, how high up the 3x3 cross tubes would be for good support. After that, it was a lot of test-fitting as I progressed.
The wheelie bar idea is interesting. On a small cart like this, it might get in the way, since the hanging hose is fairly low. I suppose it would need a vertical arm with pivot attached maybe 16 inches up the center support, and hinged braces from near the wheels, with some sort of slide/lock that would allow them to prop the arm/wheel in place.
Yes, there should be some sort of accessory trays. I had originally planned to open up the top 3x3 tubes to have built-in space. But, after cutting one open, I didn't really like it, and feared the loss of strength. I'm planning to scrounge, buy or build a couple of trays to pop-rivet in place on those arms. I'm annoyed that I threw away a cheap toolbox that came with some cheap sockets -- red metal with hinged lid, just the right size -- after it got uglied up with brake fluid.
01-26-2008, 10:50 PM #13
- Jan 2008
- Alabama
- 11
Wow! That is much more than decent execution, IMHO.
Bob
That that is is that that is not is not.
01-27-2008, 09:36 AM #14
Do yourself a favor and rotate your acetylene tank 180 degrees to get the regulator out of the path of danger. You don't want that valve subject to anything falling on it, and right now you've added a lever.
Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Thermal Dynamics Cutmaster 81
Smith O/A rig
01-27-2008, 09:54 AM #15
- Nov 2007
- West Georgia
- 103
(yes, it's a new setup)
Jim, I have since moved it 25 degrees or so to the front, having nearly clipped it at the side, while moving the cart. Being able to read the gauges from just the back side is an issue. Unlike the side clip, I can't imagine what would be falling on it. What do you have in mind?
01-27-2008, 10:02 AM #16
- Oct 2007
- Tennessee this week, Wyoming next week.
- 49
01-27-2008, 10:06 AM #17
You've never had anything fall on you? Off a shelf, off a truck, off another part you thought was clamped firmly enough...
Murphy is a real ***** when the braking force is explosive (braking as in stopping - not breaking as in broken).
Call me paranoid, but I would put a bar over your tanks to protect the valves from falling objects. Acetylene is no joke.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Smith O/A rig
01-27-2008, 10:08 AM #18
- Nov 2007
- West Georgia
- 103
Of course, I get that...
But, I don't see why it's more likely to have something fall on it there, that rotated around. And, with the gauges way back there, they could hit if the cart was driven right up to a wall. It seems that, any way you look at it, there's some risk to the gauges. And, most importantly, they have to be readable.
01-27-2008, 10:13 AM #19
The first pic you posted with the gauges they were both aimed to the left. If you rotate the acetylene to the right 180, then both of them are inboard of the 4 sides. If something fell from above, it would hit your oxygen valve first.
As bad as having a 3000psi tank bust a valve off is, I would rather deal with the rocket than the big BOOM you would incur with the acetylene seeing the same fate.Syncrowave 250DX
Invison 354MP
XR Control and 30A
Airco MED20 feeder
Smith O/A rig
01-27-2008, 02:42 PM #20
How very true. An oxygen bottle will go through the roof of your garage and possible your house and be rocketing it's way towrds freedom in under a couple seconds leaving most of the place intact. Acetylene won't be so forgiving. It will level you'r house and destroy everything inside. Out of every tool and machine in a shop that can kill or mame you acetylene is usualy the most dangerous thing you will find.
