Results 11 to 20 of 24
    Mar 2007
    132
    Great design, I really like it.
    I esp. like the pins for holding the bottle caps. Neat idea.
    You need a place to keep your spare tips. attachments, and striker, though.
    I have two of the Harper carts for my tanks. They're too expensive new, but I got them used. They're downright cheap looking and feeling compared to yours.
    Now, go get it dirty.
    -James
    Nov 2007
    West Georgia
    103
    Default Many thanks
    It's nice to hear good things from others.
    Quote Originally Posted by WACKO WELDER View Post
    No chance you would have dimensioned drawings, plans or more pictures . . .
    I would really like to build one . . . It looks well balanced and sturdy.
    I considered building one similar with the addition of a third point to the rear with a a small "dullie" wheel so it could be rolled without HAVING to support the weight. Like a small "wheelie" bar with a small dual wheel on it . . .
    Not sure if making the "dullie" pivot out on it's own when ever the cart is leaned back in preparation for moving . . . Suggestions appreciated . .
    Again, that is a very impressive looking cart . . . .
    Steve
    I have no drawings, Steve. But, I sort of wish I'd kept the 3-inch Post-It with my original sketch. It would be kind of funny to scan and post.
    I first decided how big the foot-plate would be. Then, how high up the 3x3 cross tubes would be for good support. After that, it was a lot of test-fitting as I progressed.
    The wheelie bar idea is interesting. On a small cart like this, it might get in the way, since the hanging hose is fairly low. I suppose it would need a vertical arm with pivot attached maybe 16 inches up the center support, and hinged braces from near the wheels, with some sort of slide/lock that would allow them to prop the arm/wheel in place.
    Quote Originally Posted by jamscal View Post
    -James
    Yes, there should be some sort of accessory trays. I had originally planned to open up the top 3x3 tubes to have built-in space. But, after cutting one open, I didn't really like it, and feared the loss of strength. I'm planning to scrounge, buy or build a couple of trays to pop-rivet in place on those arms. I'm annoyed that I threw away a cheap toolbox that came with some cheap sockets -- red metal with hinged lid, just the right size -- after it got uglied up with brake fluid.
    Jan 2008
    Alabama
    11
    Wow! That is much more than decent execution, IMHO.
    Bob
    That that is is that that is not is not.
  4. #14
    Oct 2006
    Mpls, MN
    1,790
    Do yourself a favor and rotate your acetylene tank 180 degrees to get the regulator out of the path of danger. You don't want that valve subject to anything falling on it, and right now you've added a lever.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Thermal Dynamics Cutmaster 81
    Smith O/A rig
  5. #15
    Nov 2007
    West Georgia
    103
    Default (yes, it's a new setup)
    Jim, I have since moved it 25 degrees or so to the front, having nearly clipped it at the side, while moving the cart. Being able to read the gauges from just the back side is an issue. Unlike the side clip, I can't imagine what would be falling on it. What do you have in mind?
    Quote Originally Posted by Fishy Jim View Post
  6. #16
    Oct 2007
    Tennessee this week, Wyoming next week.
    49
    Quote Originally Posted by EdZep View Post
    Something with "Murphy" written on it.
  7. #17
    Oct 2006
    Mpls, MN
    1,790
    You've never had anything fall on you? Off a shelf, off a truck, off another part you thought was clamped firmly enough...
    Murphy is a real ***** when the braking force is explosive (braking as in stopping - not breaking as in broken).
    Call me paranoid, but I would put a bar over your tanks to protect the valves from falling objects. Acetylene is no joke.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
  8. #18
    Nov 2007
    West Georgia
    103
    Default Of course, I get that...
    Quote Originally Posted by AnotherDano View Post
    But, I don't see why it's more likely to have something fall on it there, that rotated around. And, with the gauges way back there, they could hit if the cart was driven right up to a wall. It seems that, any way you look at it, there's some risk to the gauges. And, most importantly, they have to be readable.
  9. #19
    Oct 2006
    Mpls, MN
    1,790
    The first pic you posted with the gauges they were both aimed to the left. If you rotate the acetylene to the right 180, then both of them are inboard of the 4 sides. If something fell from above, it would hit your oxygen valve first.
    As bad as having a 3000psi tank bust a valve off is, I would rather deal with the rocket than the big BOOM you would incur with the acetylene seeing the same fate.
    Syncrowave 250DX
    Invison 354MP
    XR Control and 30A
    Airco MED20 feeder
    Smith O/A rig
  10. #20
    Mar 2007
    ****inson ND
    557
    Talking
    How very true. An oxygen bottle will go through the roof of your garage and possible your house and be rocketing it's way towrds freedom in under a couple seconds leaving most of the place intact. Acetylene won't be so forgiving. It will level you'r house and destroy everything inside. Out of every tool and machine in a shop that can kill or mame you acetylene is usualy the most dangerous thing you will find.
