Results 1 to 2 of 2
Thread: Starting Point
    Feb 2011
    1
    Default Starting Point
    What is a good starting point amperage for welding 1.750 dia. .134wall mild steel
    roll cage tubing with a 185amp inverter tig?
    Thanx Obiewrench
    Dec 2008
    Arizona
    812
    One amp per .001 wall thickness,. so for .134 wall I"d probably dial in 150 amps and pedal it back if needed.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
