    Apr 2011
    Default Gooseneck trailer plans.
    Anyone have any? Any pics of final product? Iv been looking around, but I just can't fork out the money without seeing the result.
    Oct 2008
    taxachussetts
    416
    why not just go to dealer and take pictures of new trailer. write down some measurement's?
    TB 325
    TB 302
    dynasty 200sd
    spoolmatic 30a/wc24
    suitcase x-treme 12vs
    miller 211
    evolution rage 2
    May 2009
    The Colorado Gas Patch
    185
    Default Plans?
    We don't need no stinkin' plans..
    32'
    42'
    Default Amazing
    That's the biggest, meanest, neatest, most amazing gooseneck trailer I have ever seen.
    Fabulous work man.
    Welding is so much more than a hobby. It is a fun way to earn a living working from home.
    http://www.weldathome.co.za
    May 2009
    185
    Thanks,
    It has 2 12K HD Dexter axles w/disc brakes under it.
    I used all SS steel tubing both hard and vinyl coated woven:
    Here is the Carlisle elec/hyd actuator that can develop 1600 psi in 1.8 seconds:
    I used the 1 1/2" T&G Rumber decking w/12" cross member spacing:
    Here's the 5500 Sterling that pulls it (did that deck to) All trailers and truck bed has the same width and 2" receiver tubing for stake pockets for interchangeability of accs. The straps located between the stake pockets are drilled for the hook type ratchet straps:
    Steve
    Bobcat 250EFI
    Millermatic 350P
    Hypertherm 1250
    A Bunch of tools
    And a forklift to move the heavy stuff with..
    Looking at CNC Plasmas
    It's Miller Time - Get Back To Work!
    Jan 2008
    Jayton, Texas
    12
    Www.trailerplans.com
    They have plans as well as axle kits.
    68 Lincoln SA200
    Miller pro 300
    64 Lincoln SAF 300
    Lincoln 305G
    MillerMatic 210
    More tools than a showdog can jump over
