Results 1 to 10 of 10
    Jul 2009
    Australia
    980
    Default Fixing An Old Vise
    I have around 8 vises for various jobs around the place.
    Some for milling some for drilling and some for hold stuff that I heat and pound.
    Well the other day the vise I use to hold stuff that needs to be heated or pounded broke when I used way to much force trying to grip something.
    What a shame, I love the way this vise holds on to things.
    Anyway I had to grind it to a deep vee and TIG weld it back together.
    Cast iron has a very high level of carbon content 3 to 8 percent I think so this is a major problem when welding.
    Pre and post heat is required to very high levels.
    The average gas BBQ with a hood can be used as an oven if one does not have proper facilities.
    I don't recommend anyone welding cast iron using the info from this post.
    Post fix the vise has held three things now but that does not mean that I have got it right, I will have to see how it goes over the next ten years.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    980
    Back to work.
    Ji
    Grip it and Rip it
    Nov 2009
    houston pa
    101
    im curious to know how that holds up. is it seeing the same duty as before the repair or are you giving it an easier time?
    West Farmington, OH
    746
    What filler wire did you use? I've had some good results with Royal I'm thinking it was the 11-10 but could be mistaken. I'd have to go through my invoices and look it up. I've also used 309 stainless filler in a pinch too.
    The repair looks good, I hope it holds up for you!
    Blondie (Owner C & S Automotive)
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    Too many other tools to list
    03 Ram 1500
    78 GS1000
    82 GL1100 Interstate
    Jul 2009
    Australia
    980
    Hi mikecwik,
    It has only been used 3 times since the repair.
    All 3 times has been heating with only one of them needing a hammer and that was only light.
    I will keep you posted.
    If it is no good all that means is I have to buy a new one.
    I just thought I would see if I could get it to work again.
    Ji
    Grip it and Rip it
    Jul 2009
    Australia
    980
    Hi Blondie_486,
    I used S/S filler rod.
    I hope it holds up too.
    Ji
    Grip it and Rip it
    Nov 2009
    houston pa
    101
    Quote Originally Posted by Jigantor View Post
    Ji
    nothing wrong with that....im a little tired of the throw away society myself.
    West Farmington, OH
    746
    Personally I think the old vices are far better than any of the new ones you can buy. I've been looking and it's hard to find one that isn't made in china. I have found one that may be worth a look see although it's not U.S.A. made it isn't an asian made one either. Bison makes lathe chucks and vices and are in Poland. I'd rather send my money the European direction rather than asian if I can't find it made in the U.S.A..
    What I'll probably end up doing though is buying a used American made vice from one of the wholesalers in my area.
    I'm currently working with a repaired vice myself but one which was already repaired before it came into my possession and was done poorly as far as fit up goes but it has been sturdy and has taken quite a whaling with a BFH to the part it held and hasn't broken again. But the jaws don't line up properly and sometimes it is a problem, most of the time it isn't but I'd still like one where the jaws line up the way they're supposed to.
    Miller 340A/BP
    Victor O/A torches
    Lincoln SP125
    03 Ram 1500
    78 GS1000
    Dec 2010
    Alberta, Canada
    42
    Quote Originally Posted by Blondie_486 View Post
    Nice work Ji, I agree with Blondie_486 that good vises are hard to come by. It's nice to see you were able to extend its life.
    Gord
    Jul 2009
    Australia
    980
    Thanks chaps,
    I love old vises and anvils.
    I really love the Snap On vise but they don't sell them here in Australia.
    The plane ticket costs too much.
    Ji
    Grip it and Rip it
