Do you have any trouble keeping the A/C compressor lubed up properly? Those are designed to operate in a closed-loop system with oil in the loop. I assume the oil circulates around the loop and the compressor always has enough in it. How do you lube the compressor when it's pulling fresh air into it? I'm sure it'll loose oil by spitting a little out the output. Do you just squirt a little oil in the intake every so often?
Results 11 to 14 of 14
Thread: Compressed Air Tank Carrier
04-25-2011, 11:42 AM #11
- Feb 2007
- Near Dallas, TX
- 214
Dynasty200DX w/coolmate1
MM210
MM Vintage
Lincoln AC225
Victor O/A, Smith AW1A
Cutmaster 81
IR 2475N7.5FP
Evolution Rage3
Jancy USA101
9" South Bend
AEAD-200LE
04-25-2011, 07:24 PM #12
- Jun 2008
- 1
There are oil less compressors that hook up to your v belt. I had a "york" compressor from my Ford Bronco for the air conditioning unit re-plumbed made a great compressor for filling up tires or even running some air tools off of for short times. Look up "york AC compressor" and you will find some write-ups mostly for off-road vehicles.
04-25-2011, 07:42 PM #13
04-25-2011, 08:58 PM #14
- May 2007
- Lebanon, Oregon
- 30
Andy, ....... look at what Hailea said. Mine was a "York" compressor that I took off of a Ford and installed it on my Ford. It worked great.
Bill
Miller Dialarc 250 AC/DC
Miller 251
Thermodynamics Plasma arc
Benard "Center Fire" wirefeed gun
Miller alum. spool gun
Tweco Tig torch
Victor O/A torches
B&D Wildcat 9" grinder
DeWalt 10 amp 4-1/2" grinders
7"x12" bandsaw
A shop that's always going to be to small.
