    Nov 2007
    Shattuck, OK
    84
    Default Tailgate Photos and Update
    Hey guys,
    Finally got around to taking some pictures of the tailgate that Dad and I built so here they are.
    Also thought I'd update y'all on the old Ford. Put a battery in it the other night and everything seems to work okay electrically. Wouldn't turn over at first, soon traced this to the starter relay. Robbed one of those from a 67 Ford that Larry and I had sittin in the yard and fixed that problem. Washed the motor good and poured some Marvel Mystery Oil in the cylinders to provide lubrication upon startup. Hope to try to start it tomorrow evening when i go over there. I'll keep everone posted.
    At Home
    Miller Thunderbolt XL AC/DC
    Performance Tools 6" Bench Grinder
    Craftsman Hand Tools
    Craftsman Cordless Drills
    DeWalt Angle Grinder
    1976 AMC Jeep CJ7
    1980 Ford F150 Custom
    1994 Chevrolet Silverado C1500
    At Work
    Miller Bobcat 250
    2 Miller MM251s
    2 Miller MM252s
    Miller Dialarc 250 AC/DC
    Lincoln Idealarc 250 AC/DC
    Snap-On Flux Core Welding Machine
    Hypertherm Plasma Cutter
    Victor Torches
    2006 Chevrolet Silverado 2500HD 4x4
    Proud American Ham KE5TJA
    Jul 2007
    Lancaster, Pa
    431
    Nice job on the tailgate Bryce, I like the latch idea. If I may add a bit of advice though, on the latch, it looks like you may have had a little trouble with your amperage being too low unless Im not seeing it correctly. When you have something thin to weld like a latch, get yourself some 6013 rods and run them on straight polarity, you'll be amazed at the difference.
    Ken
    Hobart Handler 187
    Dewalt Chop Saw
    4" Air Grinder
    Die Grinder
    Rigid Drill Press
    Kellogg 10hp Air Compressor
    2009 FXDC
    Hampton, Va.
    386
    Default Tailgate
    Very nice,what kind of hinges did you use. Also is the expanded metal tacked on the inside or outside.
    Thank you
    Wheelchair
    Nov 2007
    Shattuck, OK
    84
    As far as the latch goes, Dad welded that with his MM251. The expanded metal is welded on the outside and the hinges are the stock hinges from an 83 Chevy, was gonna use the original off the 94 but they were all one solid piece and we couldn't get them off the old tailgate.
    At Home
    1976 AMC Jeep CJ7
    At Work
    Miller Bobcat 250
    2 Miller MM251s
    2 Miller MM252s
    Victor Torches
    Crete Illinois
    186
    Nice gate.....looks like some of the styling is carried over into the rack on the front of the bed behind cab?
    Jim
    Welding in Crete
    Syncrowave 350 LX
    Millermatic 252
    Millermatic 180 w Spoolgun
    Miller Gold Seal 155
    Miller Elite welding helmet
    JD2 Tubing bender with Hydraulic conversion
    Evolution Raptor15" SteelDry Cut Saw
    Hypertherm Powermax 30
    Some really cool hammers BIG and small
