Results 1 to 10 of 15
    Apr 2010
    21
    Default Stick Welding Thin Steel
    Many times, I have difficulty stick welding thin steel/sheet metal without burning a hole in it. While I realize tat MIG or TIG would be better, are there any tips/tricks that result in an acceptable stick weld of this material?
    Bill
    Miller Bobcat 225
    3,972
    Use the smallest dia rods you can find like 1/16" rods...Bob
    Jul 2010
    386
    Use a chill bar behind the sheet metal to help disperse the excess heat?
    not near you
    148
    Small diameter rod...low amps...use another rod with the flux knocked off as filler rod....6011 works good....Good Luck
    Dec 2010
    383
    yea i would use a cleaned off rod with no flux and just let it build up in there . when welding on really thin stuff with a mig we would hold a soap stone behing the butt and weld it up.i never used a soap stone with stick rods though so i don't know if it would work the same.also if it's that thin did you give any thoughts to brazing it with some brass brazing rods?
    Feb 2006
    3,711
    Quote Originally Posted by bayweld View Post
    Good advice from from the above posters! I'd like to add: I agree the 6011 is a good choice. 6013's also work well and (7014 is good if in position). Check MFG recommendation for polarity: I recall 7014's have less penetration running DCEP.
    Good Luck
    HAWK
    Mar 2011
    103
    3/32" 6011 in the stinger set @ 60-90 amps, 1/8" 6011 (no flux) as the fill rod. Dip the fill rod like you were tigging or if welding flat lay the bare rod flat & run over the top of it, amperage has to be correct (high enough) to get it to work right.
    362
    6013.
    7018 on straight polarity works good too, but not as well.
    Oct 2005
    Bulverde, Tx
    1,244
    My mainstay is 3/32 6011/6010 run DCEN in the 55-60a range for 18-16ga.
    Don
    '06 Trailblazer 302
    '06 12RC feeder
    Super S-32P feeder
    HH210 & DP3035 spool gun
    Esab Multimaster 260
    Esab Heliarc 252 AC/DC
    Feb 2011
    Santa Clarita ca
    28
    Default 6011
    small diameter rod...low amps...use another rod with the flux knocked off as filler rod....6011 works good....good luck
    o i do agree but for me personally e6011 1/8 rods have been a nightmare for me as far as my current class goes i have struggled with it for months please any tips or tricks or what have you would be greatley appericated
