I'm building a pipe corral and fence with horse wire attached. I am a fair welder with some (little) expierence in vertical and overhead welding and I am getting better with my torch and grinder at fitting. I use a Bobcat 250 and was interested in rod reccomendations as well as a starting place in setting my (new) machine. The pipe I'm using is 2.375" OD structural (reject new drill pipe) that is mildly rusty and is about .240 wall. Any advice from pros or serious amatures would be greatly appreciated. Thanks!
Results 1 to 10 of 11
Thread: Pipe corral & fence
01-14-2008, 04:04 PM #1
- Jan 2008
- Plantersville,TX
- 2
Pipe corral & fence
01-14-2008, 04:21 PM #2
Rods, etc.
Welcome to the board!!!
Your best bet for welding your drillstem fence would be 1/8" 6010 5p+ or 6011. The 6010 is better and the 6011 is more readlily available. Run either one at around 75A (reverse polarity) or 85A (straight polarity). These rods produce excellent penetration and will work fine on the rusty pipe.
Good luck and pictures are always welcome here.
Triggerman
Ammonia refrigeration tech
Trailblazer 302 (yes, it's new)
Millermatic 180 w/Autoset
CST-250
HF-15 High frequency
XR15 w/Push-Pull Gun
Victor O/A, DeWalt, North mask
"A professional knows what to do. A craftsman knows why."
01-15-2008, 09:10 AM #3
- Oct 2007
- Cave Creek Az
- 797
If you are close by I'd give you a bunch of 6010 to do it with, post you location in user CP, and being the nice guy I am would teach you how to weld pipe corral with it (on my own unfinished corral of course).
01-17-2008, 08:58 PM #4
- Jan 2008
- Jayton, Texas
- 12
straight 6010 will work best. I have built literally miles of pipe fence. If it has little rust on it 6010 will work better than 5p+. I prefer uphill but that generally is only if you have the experience to do so.
On a side note 5p+ will be easier to clean up of ou are going to paint the fence. Don't forget your ospho to prime.
01-18-2008, 07:14 PM #5
Not sure what you meant to type, but 6010 IS 5P+. I've got boxes of it in my consumables cabinet.
Originally Posted by robphillips
Later,
Jason
Professional Spark Generator by Trade.
01-19-2008, 10:15 AM #6
01-19-2008, 12:00 PM #7
- Jan 2008
- 4
cutting horse just my 2 cents. i built a catch pen for cattle several years ago. the only thing that i would do different would to take out the 90 degree corners . the cattle would bunch up making the cattle harder to work. round them out or just make corners with 2 45 degre angles. wont take much just take out 90 degre corner.
01-19-2008, 01:37 PM #8
Fast Freeze, Out-of-Position Pipe Welding, Mild Steel and Low Alloy Steel Stick Electrodes
Fleetweld 5P E6010 DC+ Fleetweld 5P is a great choice for welding on dirty, rusty, greasy or painted steel -- especially in vertical or overhead applications.
Fleetweld 5P+ E6010 DC+ Lincoln’s Fleetweld 5P+ is ideal for steel that’s less than 100% clean. It’s a first choice for pipe welding, and vertical-up and overhead plate welding. This electrode is a long-time favorite among operators who handle cross-country and in-plant pipe welding.
Like I said.....6010 IS 5P+. Have a look for yourself. Scroll down the page. I don't much care what colour the coating is (up here it's gray) 6010 is 6010, and 5P or 5P+ IS 6010. I have read where pipeliner's have their preference of the two, but for this application, I think the "best" rod is unneccessary.
http://www.mylincolnelectric.com/Catalog/consumableseries.aspx?browse=104|2030|
No disrespect intended. Fact is Fact.Last edited by Black Wolf; 01-19-2008 at 02:44 PM. Reason: Adding info about pipeliners
Later,
Jason
01-20-2008, 10:12 AM #9
- Oct 2007
- Cave Creek Az
- 797
As best I recall 5P and 5P+ are Lincolns recipes for 6010. I looked into it a little bit and they all meet guidlines for being 6010 but the amounts of alloying metals in them differ to give better characteristics for pipeline welding. So, all 5p and 5P+ is 6010 but not all 6010 is 5p or 5p+. For pipe corral I think any ol' 6010 that you have would work just great.
01-20-2008, 11:33 AM #10
- Dec 2005
- minnesota
- 6
I have built a corral and alley way into the chute for cattle. I would suggest 6010 or 7018. I've used both on mine. It isn't a critical weld like a pipeline. You don't need 100% penetration just 1 good pass. I like 7018 over 6010 just because it looks cleaner. If it's a sound weld it doesn't matter, the cows or horses will never break it.
