Results 11 to 13 of 13
    Oct 2013
    I got a 225G yesterday with same problem. Wont go to high speed under load when on turtle. Runs fine if left on rabbit.
    Duane, I did all these checks and everything checks good except on the ICM, pins G-E measured 2.5mvAC no load. I know you say 0 vac so does 2.5mv mean its bad?
    Also where to buy the icm if it is bad. M4less wants $236. Seems a little high to me?
    Thanks to all for giving this info
    Oct 2013
    Btw, pin D on my ICM does not have anything on it. Is that normal?
    Aug 2008
    Orange, TX
    1,217
    Yes, normal. Terminal D isn't used on the Bobcat.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
