Results 1 to 10 of 13
    Apr 2011
    17
    Default BOBCAT 225 speed soleniod testing?
    Hi, New to the discusions...Have a Bobcat225 that won't idel down in RUN IDLE setting. How would I test the soleniod on it? I have a volt meter available. Thanks
    Aug 2008
    Orange, TX
    1,214
    If your meter has an Ohm setting, use it to check the solenoid coil for being open (bad) or for continuity (good). If no ohm meter, use a 12V battery and test leads to check to see if the solenoid will energize (pull in).
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
    May 2008
    Mpls, MN
    464
    If it will not idle down unplug one of the wires. If it idles down move on to the control board (i assume). If it does not idle down you have some thing stuck in the solenoid.
    Owner
    DW Metalworks LLC
    Miller Trailblazer 302
    Miller 8RC Feeder
    Miller Passport Plus
    Miller Dynasty 200 DX W/Coolmate 1
    Hobart Handler 135
    Hypertherm PowerMAX 30
    Smith O/A Torch Set
    Plus more tools then my wife will ever know about....
    Apr 2011
    17
    Thanks guys, will try that. Geo.
    Aug 2008
    Orange, TX
    1,214
    On the Bobcat 225, the solenoid energizes to bring the unit to low idle speed and de-energizes to increase to weld/power speed.
    If the solenoid coil proves good with the continuity check and it pulls in on the battery test, make sure there is 0 volts AC between idler control module terminals G and E with the unit running and no weld/power load on the unit.
    Confirm there is battery voltage between idler module terminals B and E with STOP/RUN/START switch in RUN/IDLE position.
    If the above checks out and there is no battery (+) voltage at idler module terminal C after 15-20 seconds with switch in RUN/IDLE position after a weld/power load is removed or after unit is first started, the idler module is bad.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
    May 2009
    Muskogee Oklahoma
    245
    Also check to make sure that the plunger rod isn't bottomed out inside the solenoid. Sometimes the vibration on the engine will cause the bolts holding the solenoid to come loose and first time it tries to kick down, the solenoid will pull toward the plunger instead of the opposite.
    Apr 2011
    17
    Smile
    Thanks gents! By the way the soleniod checks out good. Reads 2.51 ohms. both ways. Where is the idler modual located? Is it the same as the idle run switch? And if possible where are the circut boards located? Thanks Newby here...
    May 2009
    Muskogee Oklahoma
    245
    Idle control module is under the cowling on the back of the control panel. It's a red box with spade terminals on it.
    Aug 2008
    Orange, TX
    1,214
    Depending on the unit's year of manufacture, the idle control module may be here. . .
    . . . or here.
    Syncrowave 180 SD
    *HF-251D-1
    PakMaster 100XL
    Apr 2011
    17
    Yup, It turned out to be a bad soleniod. Purrs like a Kitten now! Thankyou Geo.
