A few projects I've done over the years.
Results 1 to 8 of 8
04-14-2011, 04:39 AM #1
I'm new here. This is some of what I've done
Miller Syncrowave 350 LX
04-14-2011, 04:40 AM #2
04-14-2011, 04:42 AM #3
04-14-2011, 10:07 AM #4
- Jun 2010
- Indianapolis Indiana
- 200
Awesome pictures and thanks fr sharing
Miller 330 BPA - Sold
Miller 180SD Syncrowave - Sold
Miller Aircrafter 330ST - Sold
Miller 351 Syncrowave - Sold
Miller CP-300
Miller Maxstar 150 STL
Miller Dynasty 200 DX
Miller 135 Millermatic
Miller Spectrum 250D (Now running strong!)
04-18-2011, 08:51 AM #5
I get the pipe and flanges, but what are the round thingys?
Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
04-20-2011, 01:50 PM #6
It's designed to draw water through the filters at the bottom of a tank filled with some type of crushed rock. Part of a water filtration system. Entirely 316 ss and has to match threaded rod that is welded to the bottom of the tank which was welded by a supplier before rubber lining. Meaning, someone else welds the tank and then it gets rubber lined. Then I had to build that ring assembly with the bolt hole pattern already in it and make the entire assembly fall together without use of pry bars and come alongs. Because the whole thing gets assembled inside the tank. This is just a pre-assembly to prove it fits.
If all that makes any sense.
04-20-2011, 07:29 PM #7
- Apr 2010
- Jackson, MS
- 74
Those welds are pretty incredible. That level of skill is something I aspire to.
MillerMatic 252
Spoolmate 200
Diversion 165
Spectrum 625 X-Treme
Dayton 6" Miter Band Saw
Delta Drill Press
Bosch 10" Table Saw
Jet 5 Ton Chain Hoist
Radnor O/A
04-22-2011, 09:24 PM #8
- Mar 2011
- MEXICO MO.
- 11
you do real nice work! You do not have to take the back seat to anyone with welds like that!!!!!!!!!!!!! You are not working on your first 10#s. Good luck an keep up the good work!!!!!!!!!
