Results 1 to 10 of 16
    Dec 2009
    Texas Gulf Coast
    30
    Default Just Another Trailer
    I'm almost finished with this 5 x 10 utility trailer. I'm maybe saving about $300 building it myself but there's a lot more than that in labor. But it has been fun for the most part.
    1,928
    Looks good. Don't know what you are going to carry but with the axle that far back you can easily overload the angle you used for the tongue. If you plan on really loading it I would swap the angle for tube on the tongue. You could even put a pc. of tube inside the angle to stiffen it.
    I say this as most people tend to load the front first & if your getting firewood, gravel, dirt etc. the majority of weight will be in the front 6 feet of the trailer which is in front of the axle.
    The weakest point is where the angle exits from under the deck.
    Deltaville, VA
    2,239
    Is that axle really sitting directly on the trailer frame?
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
    Nov 2008
    Colorado Springs
    276
    I think I see a spring, Its just the camera angle.
    A 60% set back on the axle from the front of the trailer box is the proper location.
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    Hypertherm PowerMax 1000
    20" x 40" CNC Mills (2)
    16" x 60" engine lathe
    65 Ton edwards iron worker
    3/16' x 24" power slip roll
    16' power feed mitering bandsaw
    and other fun toys
    Quote Originally Posted by 1havnfun View Post
    !0% back of center of balance is all it really takes to put the weight on the hitch.
    Nov 2008
    Colorado Springs
    276
    lELet me see....
    50% + 10% = 60% back from the front of the box.
    I do believe that is what I said.
    Oh Donald, the hitch has nothing to do with this calculation, only the box or platform.
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    and other fun toys
    Dec 2009
    Texas Gulf Coast
    30
    [QUOTE=MMW;263202]Looks good. Don't know what you are going to carry but with the axle that far back you can easily overload the angle you used for the tongue. If you plan on really loading it I would swap the angle for tube on the tongue. You could even put a pc. of tube inside the angle to stiffen it.
    I was going to use 3" channel for the tongue but that would have been $50 more & since I had 10' of 3" x 2" x 3/16" left over from the frame material I decided to go with it. I'm going to put a brace from the top rail to the cross member in the tongue to at least stiffen it a little & just keep an eye on it.
    As for the axle it is NOT on the frame, it is on leaf springs & it is indeed 2/3 from the front of the frame.
    Nov 2008
    Colorado Springs
    276
    The one thing I didn't mention...
    Nice looking trailer and it looks like it'll do the job.
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    and other fun toys
    Dec 2008
    Arizona
    812
    2/3 = 66%, not 60%, which was pointed out to be the correct location.
    Miller Syncrowave 200
    Homemade Water Cooler
    130XP MIG
    Spectrum 375
    60 year old Logan Lathe
    Select Machine and Tool Mill
    1,928
    The above isn't even my quote. It was written by the OP after he quoted what I wrote in post #7.
    Wow guys I'm sorry I commented on this. It seemed to start a debate about proper axle placement. If you re-read my original post all I basically said was the tongue looked light compared to the axle location. No where did I state the axle was in the wrong place.
