Results 1 to 3 of 3
    Default Gas solenoid for Maxstar 140
    Could someone tell me if the newer model Miller Maxstar 140, the ones that have a remote receptacle on them have a gas solenoid or do you have to turn the gas on and off via the torch knob?
    Feb 2007
    Central IL
    179
    The Maxstar 150STL and STH have a gas solenoid that will turn your gas on and will give you a 10 second post flow that is non adjustable. Good enough for most cases.
    Flash me! I'm a welder.
    American by birth, Union by choice! Boilermakers Local 60
    America is a Union
    I realize that the 150's have the solenoids, I owned a STH but sold it. Got a deal on a 140 and was wondering if it has a solenoid , have not received the unit yet.
