Results 1 to 10 of 14
    Apr 2011
    Default Building a bullet trap
    I got a call from one of my customers today wanting a "bullet trap for a gun range in a house he is building. When I met with the customer he wants a trap 8' Wide with a long sloping (45 degree slope)up to 8' and then a top sloping down to meet the bottom plate. My questions are Does anyone have experence with this? I was looking at 5/8 AR500 material. They plan on covering the bottom sheet with "rubber mulch" 1 to 2 feet thick. I was reading about AR materials here seems like preheat is a must. Well guy I look forward to hearing of your thoughta and experences.
    3,972
    Here is a small one and some other info...Bob
    http://www.millerwelds.com/resources...ht=bullet+trap
    Jun 2006
    Maine
    732
    The biggest question would be what are they planning to shoot at it with? if it's just a .22LR, an angled piece of 3/16" mild steel and a sand trap would work fine.... larger pistol rounds... a larger version of what AAmetalmaster built would be great... the pipe acts as a spiral decelerator... you really don't need any fancy steel for rimfire or handgun rounds, just up the back plate to 3/8 for large caliber handgun.
    steel traps for jacketed rifle rounds are a bad idea..... bits of the jacket can travel straight backwards over 50 yds!
    the up angled lower plate sounds like a really bad idea to me as well.
    Bobcat 225NT
    Cutmaster 52
    Lincoln Weld-Pak 100 buzz box
    Caterpillar TH63
    '07 Kawasaki ZZR600
    Nov 2010
    Central Kalifornia
    64
    Default Bullet Trap
    Go to or better yet, Call the NRA. They have the plans drawn for all kinds of bullet traps, that are caliber specific. When you call you want Range Development or something like that.
    Mar 2011
    iowa
    11
    Thumbs up Bullet Trap
    I have shot every thing from 17 HMR to 50 cal be carefull every round reacts dirrerent under different conditions. This can get you hurt bad. I would suggest a heavy rubber curtian infront of the angled back plate to help prevent splash back But the NRA is defenitley the authority!!!!!!!!!!! Good luck and good shooting.
    Mar 2011
    103
    Liability insurance paid up ?
    Nov 2010
    Central Kalifornia
    64
    If you have trouble getting a hold of the right location at NRA PM me and I will dig up some phone numbers and a maybe get lucky with a name.
    Dec 2010
    Alaska/Oregon
    27
    Very well made points above, I have used all kinds of indoor traps and ranges, over a thirty year span of time. Even handgun bullets can and will produce "frag" that can come right back up range at the shooter or any bystanders. The more modern traps minimize this greatly of course but it can still be an issue. I would take a photo of the very modern one I was involved with recently, but am no where near it at the moment, and cannot recall who the comm. mfr. was.
    Proper ventilation is a huge issue as well that you are probably aware of. If the buyer is not planning on doing it all up right, you might want to think twice about being involved with it. Hopefully, your reference sources will be well rounded in that they will discuss ventilation and the other HAZ MAT (somewhat minor in a low use, well vented home range...but still present) issues in play with such a project. I know there are hundreds of rigged up "tubes" and other such set ups in basements everywhere. It sounds like this customer wants a bit more than that and perhaps you can fully educate him after some more research. Otherwise, I'd expect he would know exactly what he wanted and have a plan to show you, regarding the metal work. Such does not seem to be the case as of now.
    It does sound like a fun project, hope it comes together and you can report back to us here. Would very much like to see pics of what you come up with.
    Dec 2009
    CT
    11
    Default Bullet trap
    Having built and owned a public indoor shooting range I can tell all bout splatter! Bullet splatter goes in all directions so you will need side wall protection as well as above the traps and in front. The best best would be to recommend a commercial set up. Most manufactures will make them to any spec's and the price for the right set up is not all that bad. We used Caswell equipment and 20 + years later of heavy use it still has a long life.
    Jun 2010
    Michigan
    23
    The indoor range I shoot at uses 1/2" thick AR500 (I believe) They also made a front stop incase a bullets takes a weird bounce after hitting the sand in the pit.
    Millermatic 250
    Miller bobcat 225g plus
