Results 1 to 10 of 18
    Default Recommended gas pressure
    I am new to mig welding and am unsure about what a recommended gas pressure should be. Can't seem to find this information anywhere I have been looking.
    I use a co2 / argon mix.
    Aug 2010
    1,099
    You talking about pressure or flow?
    For flow, it depends on your welding habits, size weld, position, and the diameter of the cup.
    For reference, I start at 20cfh for a 5/8" ID nozzle, 30 cfh for a 1" nozzle, and adjust from there.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
    I was thinking pressure.
    Is flow based upon pressure or nozzle size?
    Nov 2008
    Colorado Springs
    272
    Most of the regulator/flowmeters are preset for the presure and you can't change that.
    Like shovelon stated your flow is adjusted for your apllication and equipment.
    If you have a small mig machine(less than 250 amps) start at 15cfh and adjust from there.
    to little and you will get a bad weld and to much you will get a bad weld.
    use as little as you can to get the best results
    Live Right Have Fun
    XMT350 CV/CC
    22A Feeder
    MM175
    TB302
    12vs Extreme
    Hypertherm PowerMax 1000
    20" x 40" CNC Mills (2)
    16" x 60" engine lathe
    65 Ton edwards iron worker
    3/16' x 24" power slip roll
    16' power feed mitering bandsaw
    and other fun toys
    May 2010
    Central CA
    711
    The OP must have the double pressure gauge type of flow meter.
    One gauge tank pressure, one gauge regulated pressure.
    I don't know the psi setting.
    Good Luck,
    Bob
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    30A w/ WC-24
    HF-251D-1
    Select Lathe
    Exact Mill
    Spectrum 625 X-TREME
    Cutmaster 152
    Kalamazoo Band Saw
    SX60 Arc Station
    FX30 Arc Station
    8-Grinders
    5-Victor O/A
    4- Chop Saws
    2-Drill Presses
    Lincoln SA-200 Blue Tint Red Face
    Lincoln SA-200 Red Face
    1,565
    The one gauge tells you tank pressure. You can't change this as it will decrease as the tank empties. A full bottle should be in the 2000 to 2500 range. This will change with temp though. The other gauge or sight tube usually shows cfh which should be set at about 15-20.
    I have used 12 CFH., with good results. No need to over do it.
    30 CFH is too much for a 110v MIG machine.
    It does tell you in your instruction manual.
    Quote Originally Posted by Donald Branscom View Post
    Well I was incorrect. The manual for the Millermatic 200 does NOT give any info on shielding gas adjustments. All it says is that different gas mixtures have different requirments as far as pressure and flow.
    This is a good source of info. http://www.netwelding.com/sales_literature.htm
    Thanks all.
    2,634
    Quote Originally Posted by hitchingrail View Post
    where you been looking?
    http://www.google.com/search?client=...UTF-8&oe=UTF-8
