Results 1 to 3 of 3
    Apr 2011
    1
    Default Diamondback Torch Leaking Blue Hose
    Hello-
    We have a Miller Syncrowave 250 DX with the optional Tigrunner cooler. We are using the Diamondback Torch with this, but the blue cooling hose is leaking near where the line comes out of the Tigrunner cooler.
    Does anyone know how I might get a replacement hose for this? I don't know a lot about welding equipment, so I'm really hopeful that someone who does might be able to help!
    I called one place, who said the Diamondback was discontinued and I have to buy a whole new torch, hoses, etc... Does this sound right?
    Thanks so much!!
    Dalton
    May 2010
    Central CA
    785
    Default Splice
    Would it be possible to splice it or cut it off a little shorter, and put the old end back on the hose.
    I do that to my O/A torch hoses all the time. Those hoses are down to about 15' long now. Everytime they leak at the torch handle I cut off 6" and crimp on new fittings.
    I keep the cart close to my work.
    Good Luck,
    Bob
    Millermatic 252 w/30A
    Big Blue Air Pak
    Ellis 3000 Band Saw
    8-RC
    Dynasty 200 DX
    XMT 350 MPa w/S-74 MPa Plus
    Millermatic 211
    Passport Plus
    Spectrum 625 X-TREME
    2-Lincoln SA-200 Red Face '68
    SA-200 Black Face '59
    SA-200 Green Lite '84
    SA-200 Green Lite '80
    SA-200 Red Face '69
    SA-200 Red Face '66
    SA-200 Green Lite '81
    '70 Black Face Round Barrel
    Mar 2007
    Deltaville, VA
    2,239
    The diamondback torches were made by Weldcraft.
    Just order the right length weldcraft water hose (rubber, hi flex) for the 20 Series torch.
    Pretty sure IOC or Cyberweld stock them.
    Might also want to order a few SS wire ties along with the hose. As well as I remember the Diamondback torch connectors were push on with wire tie vs the screw on type that Weld Tec uses.
    Edit.
    Cyberweld has what you need (Weldcraft part # 45V08R--25') for $66.11.
    BRWelding has the same 45V08R--25' for $59.00.
    Looks like the hose has screw connectors on both ends so you may not need the SS ties. Can't remember if my Diamondback torch (came with the Sync 250) has the screw on hoses (torch end) or not. I know the Weld Tech Speedway torches I use have the screw on connectors at the torch.
    Syncrowave 250 DX Tigrunner
    Dynasty 200 DX
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
Tags for this Thread
