Results 1 to 8 of 8
Thread: Long Welds
    Aug 2007
    674
    Default Long Welds
    Hey Guys,
    This is probably a basic question, but here goes. I have a tendency when making longish welds (over 6") to want to stop and reposition myself and then continue on with the weld.
    1. Is this incorrect?
    2. If this is correct is it as strong as a continuous weld?
    3. In addition when you stop and start is there a technique to make the weld appear continuous?
    Thanks,
    Nick
    MM210 75/25 Ar/CO2 0.35 Wire
    Aug 2007
    Seattle,WA
    55
    I got over this problem by keeping my upper body rigid and taking small side steps with my feet. Allow for a little bit of play with your arms so you don't move the gun around when side stepping. Or you can start by leaning over where you are going to start so you are giving your self a foot or so of weld befor you get to be upright.
    Welders do it hotter!!
    www.Munsonworks.com
    Dec 2006
    Alaska
    732
    Quote Originally Posted by kiwi View Post
    Hey Guys,
    Thanks,
    Nick
    Relax no problems with having a restart every 6"-8". Just think of it this way how long would a SMAW stick get you about 6-8"'s
    A bit of grinding on the leading edge of your weld (the point where you are going to restart) making a small notch to restart in is all that is needed.
    TJ______________________________________
    Aug 2007
    674
    Thanks for the info!
    Glad to see you on the board TJ!!!!
    Nick
    Jan 2007
    Rosetown, SK.
    514
    I use Andy's method of 6 - 8" beads,reposition & when I restart I go about 1/8" ahead of where I stopped I once started back quickly into where you stopped beore & then continue on. Seems to work O.K. for us.
    Dec 2006
    Alaska
    732
    Nick
    Thanks Nick
    I will pi$$ someone off soon and will have to leave again, but such is the life of someone so gifted as me lol
    Your question was a good one in that I have seen other allude to the idea that a single long or single pass weld is always better than a multi pass or interrupted weld.
    Welding done correctly will not know it was multi pass or interrupted.
    Aug 2007
    So. Cal
    335
    Default Duty Cycle..
    Don't forget your duty cycle on those long welds.
    TacMig
    We depend On:
    Burco/Koco | Onan | BobCat
    We belong to or support:
    American Welding Society
    The Welding Institute
    Anderson & Co. LLC
    Metal Cr
    afters
    Dec 2006
    collinsville, ok
    86
    i do alot of long welds and the first thing i can say is if you brace with a wrist, forearm, elbow, whatever, don't put your weigt on it. just use it to steady the other hand. as for making restarts look good stop on your starts.
